Progress on "internal problems"
- Progress on "internal problems"
07-08-2007 3:27 PM
Is there any way to find out how an "internal problem" is progressing?
I raised a ticket (22459215) just over a week ago as mail is still being sent to an account that I deleted a redirect to. I was told that my problem had been assigned to "internal problem 43666".
Is there any way to track it as it doesn't appear on the list of issues I can see via the portal?
Message 1 of 5
(1,776 Views)
4 REPLIES 4
Re: Progress on "internal problems"
07-08-2007 3:46 PM
No they are not trackable by customers. All you can do is 1) see if a comms agent sees this and can check or 2) ask in a ticket on the progress.
Message 2 of 5
(603 Views)
07-08-2007 4:00 PM
That particular problem is with a developer at the moment and is being worked on. We should have some more progress in terms of the fix over the next couple of days.
Message 3 of 5
(603 Views)
07-08-2007 4:01 PM
Further to the above, all priority 1 problems are published to the portal, however this particular issue is a priority 2 problem so is only available on the internal network.
Message 4 of 5
(603 Views)
07-08-2007 4:20 PM
Thanks for the replies.
Already asked in the ticket - was just curious as to whether these could be tracked!
Hopefully there'll be a fix soon!
Message 5 of 5
(603 Views)
