Profiles again... why does a brief glitch have to be so heavily punished?
- Profiles again... why does a brief glitch have to ...
- « Previous
- 1
- 2
- Next »
Re: Profiles again... why does a brief glitch have to be so heavily punished?
15-02-2010 6:02 PM
Router has been in the test socket most of the day. Will do a reset (with another filter) later on tonight when it's quieter.
Cheers for now
15-02-2010 10:29 PM
Quote from: dave On the tickets issue, unfortunately if a customer comments on a ticket that is currently waiting to be answered it will push it to the back of the queue, this isn't by design and yes we do want to fix it so it doesn't happen, but the fix isn't a simple thing to achieve. I can't remember off hand what the latest is, but while I've been typing this I've thought of a better way of picking up tickets caught like this than we currently have.
This really does need fixing. I have an intermittent fault that comes and goes very quickly, yet it takes tickets up to 5 days to be answered after updating them - by which point the fault is history and the CS rep replies that BT have found nothing. Also the DLMs 'one size fits all' approach must generate a lot of unnecessary work and irritation for everyone.
16-02-2010 7:11 AM
Line Mode G.DMT Line State Show Time
Latency Type Interleave Line Up Time 00:00:16:20
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 1664 Kbps 448 Kbps
Noise Margin 16.4 dB 16.0 dB
Line Attenuation 14.0 dB 7.0 dB
Output Power 11.8 dBm 12.3 dBm
BT IP profile: 1250K
So how do go about getting the S/N down?
Excuse my ignorance, but I'd have thought a higher S/N would have been more desirable.
16-02-2010 9:49 AM
What router have you got
16-02-2010 10:19 AM
My newer Linksys WAG54G wouldn't hold a steady connection when I was moved onto 21CN. I suspect this has caused some of my problems.
16-02-2010 11:18 AM
Also does the Voyager give a good connection on its owner's line (to confirm it is not also faulty)?
16-02-2010 11:53 AM
Voyager worked well (as did my Linksys) on the other network, albeit 20CN.
So can someone explain why a high S/N is undesirable, it doesn't make sense to me.
16-02-2010 12:27 PM
Am I right in thinking that DLM increases the SNR to an artificial level to compensate for intermitant connections?
If so, as my line has been stable for days now, it should be reducing it, no?
Or am I being naive?
16-02-2010 12:31 PM
16-02-2010 3:34 PM
To me it looks like there is something seriously wrong with your connection, which from the tests you've done appears to be external to your property. I think you said you had a fault ticket under investigation? What feedback are you getting on that?
16-02-2010 4:51 PM
Only the borrowed router & one phone in the test socket, so effectively ruled out everything else.
I just replied to the ticket yesterday with added information, so I don't expect to hear anything for a day or two. I'll probably wait for another 3 day period and phone them.
At least I've got a reliable connection, albeit running around 1Mbps!
- « Previous
- 1
- 2
- Next »
