Profile speed needs a push
- Profile speed needs a push
12-08-2013 10:19 PM
I had to fit a new carpet on saturday so the phoneline and pc and everything were unpluged, Since then my speed has seemed slower than usual so i reset the modem again but had the same speeds so diden't think anymore about it untill tonight.
Got chatting to someone on facebook and ended up doing the bt speed test and i noticed my line speed is 40.55mbps but my plusnet profile is only set at 36mbps roughly.
http://img.techpowerup.org/130812/Untitled693.png my speed test on bt site.
Re: Profile speed needs a push
13-08-2013 7:11 PM
14-08-2013 9:32 AM
23-09-2013 6:12 PM
Would it be possible to get it changed again please.
1. Best Effort Test: -provides background information.
Download Speed
36.44 Mbps
0 Mbps 41.76 Mbps
Max Achievable Speed
Download speed achieved during the test was - 36.44 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-41.76 Mbps .
Additional Information:
IP Profile for your line is - 41.76 Mbps
Seems to keep getting higher for some reason and i have not restarted the modem.
23-09-2013 6:14 PM
23-09-2013 6:18 PM
Can the profile on BT's end get higher without a loss of connection to the modem?
Just suprised its higher than before, Would have thought it would be lower if there was a d/c.
Thanks again. All working good cheers.
15-12-2013 1:53 PM
Download speedachieved during the test was - 32.1 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-38.72 Mbps .
IP Profile for your line is - 38.72 Mbps
Plusnet Profile...
Current line speed:
33.8 Mb
Thanks in advance
16-12-2013 11:11 AM
16-12-2013 5:35 PM
Untill it droped out about a month ago it was happy at 42Mbps roughly at BT's end then for no reason at all i noticed the drop to 32Mbps then after changing the cable yesterday it went back up to 38.7 BTs end.
16-12-2013 7:35 PM
Can someone check my speeds as well? They are a LOT slower than they should be.
16-12-2013 7:56 PM
That's been changed to 38.8 for you and if you log into your router and disconnect then reconnect you should see a difference
@bobcharles
Your profile is set correctly on our end and BT's. If you run through our fault checker at http://faults.plus.net and we can look into this further
17-12-2013 9:30 AM
Thanks again and keep up the good work.
