Profile reset
- Profile reset
Profile reset
09-08-2012 5:28 PM
Hi
I previously had an issue with my line speed as of this thread http://community.plus.net/forum/index.php/topic,106613.0.html
BT have now fixed the issue with my line so it should all be good from my end. i have run the speed tests again and it looks like my profile has dropped from what it previously stood at when I first ran the tests.
Could my profile (up and down speed) please be reset as of my previous tests
Cressa
DSL Connection
Link Information
Uptime: 0 days, 0:57:51
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 22.778
Data Transferred (Sent/Received) [MB/MB]: 4,15 / 26,11
Output Power (Up/Down) [dBm]: 11,6 / 0,0
Line Attenuation (Up/Down) [dB]: 6,3 / 14,0
SN Margin (Up/Down) [dB]: 32,9 / 3,1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 12 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 16
HEC Errors (Up/Down): 0 / 36
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
9.39 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 9.39 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 20.09 Mbps
Upload Speed
0.23 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.23Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
10.3 Mb
jim:green IP address removed mod:end
Cressa
DSL Connection
Link Information
FAQ
Download Speed
9.39 Mbps
0 Mbps 21 Mbps
Upload Speed
0.23 Mbps
0 Mbps 0.45 Mbps
Current line speed:
10.3 Mb
Message 1 of 6
(5,483 Views)
5 REPLIES 5
Re: Profile reset
09-08-2012 5:34 PM
There are two different problems
The Plusnet profile needs to be raised to match the BT IP profile - without intervention this should take 2 or 3 days
Your upstream has been capped - you need to request it be uncapped
Message 2 of 6
(647 Views)
Re: Profile reset
09-08-2012 6:13 PM
Hi
Do I need to raise a fault to have my upstream uncapped ?
Message 3 of 6
(647 Views)
Re: Profile reset
09-08-2012 6:18 PM
nope - just a normal ticket
Message 4 of 6
(647 Views)
Re: Profile reset
09-08-2012 6:43 PM
I've uncapped the upstream for you, this will take around 24 hours to take effect. Your Plusnet Profile is set correctly, are still seeing poor throughput speeds?
Message 5 of 6
(647 Views)
Re: Profile reset
09-08-2012 7:22 PM
Hi
im still getting around 9.71mbps downspeed, if I do a speed test. From looking at my profile before the line fault with BT this was set to around 20mbps and I would get around 18mbps download - will my profile reset itself back to this in a couple of days
Hi just reset my router after seeing my profile has been reset and the speeds are back up to normal again
I'll just wait to see the uncapping work on my up and I should be good to go, thanks for your help
Message 6 of 6
(647 Views)
