Profile raised again please
- Profile raised again please
14-07-2011 10:26 AM
Re: Profile raised again please
14-07-2011 11:33 AM
14-07-2011 6:16 PM
Home Image not loadedTesting Image not loadedResult Image not loaded
FAQ
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
3895 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 3895 Kbps
Additional Information:
Your DSL Connection Rate :5504 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
14-07-2011 7:15 PM
Sadly I imagine the values will be reconciled at 4500kbps unless you have scope to achieve a sync speed of 5696kbps (current noise margin around 1½dB above the target value).
14-07-2011 7:40 PM
14-07-2011 7:55 PM
Download Speed
4631 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 4631 Kbps
Your DSL Connection Rate :5952 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
14-07-2011 8:19 PM
Is your router one that works with the RouterStats monitor, eg the Thomson TG585v7 or v8 supplied by Plusnet?
14-07-2011 8:38 PM
14-07-2011 9:28 PM
15-07-2011 12:59 AM
Checking on how noise margin varies with time would be useful, in case the value drops low enough to cause loss of sync. RouterStats provides constant monitoring if you can get it to work with that model of router. This post provides a guide to configuring RouterStats.
15-07-2011 11:59 AM
The line's now syncing at 6080 but it's only been connected for 16 hours so far. It'll need to be a little longer before the IP profile picks up.
Jojo
15-07-2011 12:18 PM
18-07-2011 12:24 AM
Download Speed
3798 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 3798 Kbps
Your DSL Connection Rate :5856 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
18-07-2011 3:20 PM
This is part of a problem we have raised with our supplier. I'll keep you informed when we have more information.
Jojo
19-07-2011 12:35 PM
