Profile number, only see if do BT speedtest??
- Profile number, only see if do BT speedtest??
15-10-2010 4:15 PM
IOW, is doing the BT speedtest the only way I can find out my Profile?
Message 1 of 5
(754 Views)
4 REPLIES 4
Re: Profile number, only see if do BT speedtest??
15-10-2010 4:34 PM
No, you can ask us
Message 2 of 5
(400 Views)
15-10-2010 4:44 PM
The BT test is the only way to see what BT say it is.
https://portal.plus.net/my.html?action=data_transfer_speed ; tells you what it is on PN's system.
The two should match, of course, but the PN figure will lag the BT one by up to 24 hours. Whichever is the lower will apply.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 3 of 5
(400 Views)
15-10-2010 4:59 PM
Hi fishrow,
Just ran a line test and your IP profile is 10000, so I've matched our profile and if you disconnect and reconnect via your router interface you should see the change.
Jojo
Jojo
Message 4 of 5
(400 Views)
16-10-2010 11:44 AM
thanks for reply
Message 5 of 5
(400 Views)
