Profile mismatch?
- Profile mismatch?
Profile mismatch?
28-07-2010 9:03 PM
This evening I noticed my connection seemed to be a little slow so I did a speed test and got around 450K - which is about a quarter my norm. I checked the router and O was synched at around 500 so promptly did a reboot.
My synch is now 2700 and my line profile according to PlusNet is 2500 - both my normal settings. But a speed test from BT shows the following:-
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
454 Kbps
0 Kbps 500 Kbps
Max Achievable Speed
Download speedachieved during the test was - 454 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :2784 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
My BT profile appears capped at 500K - can anything be done about this? After all - I've just syncjed at 2700 and PlusNet tests give me a min of 2000 and a current profile of 2500
Download Speed
454 Kbps
0 Kbps 500 Kbps
Message 1 of 3
(904 Views)
2 REPLIES 2
Re: Profile mismatch?
28-07-2010 9:12 PM
Unfortunately not - it will take a few days for the BT value to increase.
It looks as though the Plusnet value hasn't picked up the low value yet - but it will
Message 2 of 3
(450 Views)
28-07-2010 10:00 PM
I can think of only one word in reply. It begins with "B"
Thanks Oldjim - I think
Message 3 of 3
(450 Views)
