Profile, is this correct?
- Profile, is this correct?
06-08-2014 2:08 PM
Saw this comment over at another forum, is this correct -
Plusnet internal IP profile shaves 1-2Mb/s off max throughput.
http://forums.overclockers.co.uk/showpost.php?p=26711961&postcount=13
Message 1 of 2
(475 Views)
1 REPLY 1
Re: Profile, is this correct?
06-08-2014 2:49 PM
Hi PLan,
You will see a difference in speed on both the sync and throughput of the profile on the account side as the overheads need to be taken into account.
With Fibre you would see a formula of ( sync speed * 0.967 = profile speed )
With ADSL2+ you would a formula of ( sync speed * 0.882 = profile speed )
So while there will be a slight difference, it isn't as straightforward as the quote you provided in your initial post.
Message 2 of 2
(305 Views)
