Profile differences
g3uiss
Profile differences
Hi
I'm trying to understand after some issues with the DLM reducing my speed the differences between BTW and the Plus net quoted line speed.
My BTW test (Attached) indicates a IP profile of 19.82 hence a sync sped of 20.50. However the Portal reports my line speed of 19.8 very small difference but why ?
(Earlier post refers and closed ticket)
Tony
jim:green telephone number removed from image mod:end
Fixes: 58
Re: Profile differences
The Plusnet profile is BT IP profile rounded down to the nearest 100kbps
g3uiss
isn't the difference in the Sync speeds 20.5 - 18.8 = 700kbps or are you saying the "Line Speed" as quoted on PlusNet is not the line speed but the IP profile ? It never was before ?
Fixes: 58
The actual wording is
What does "Current line speed" mean?
The speed shown above is based on your sync speed. This is always a little higher than the speed at which data will actually be downloaded over your broadband connection
which is factually correct but clear as mud
Actually it is based on the IP profile which is 88.2% of sync speed and this has always been the case although on 20CN the IP profile was calculated differently
g3uiss
IP profile is .987 of Sync speed not 88%
However is that figure on the Portal Sync Speed or IP profile?
In either case it doesn't match the BTW test figures so one must be out by some degree morte than 100kpbs !
Fixes: 58
You are getting confused
The figure you quote 0.987 is actually 0.968 and is applicable only for FTTC not ADSL
For ADSL it is 0.882 as I stated
By the BT test figures I assume you mean the speed test result as this is always a bit lower than the profile
I have previously explained how the Plusnet profile is calculated
g3uiss
Perhaps your confused by my post I'm on FTTC not ADSL.
Hope that makes the query clearer.
Plusnet Staff
Plusnet Staff
Fixes: 159
Where are you seeing your sync speed?
 Chris Parr
 Plusnet Staff
Fixes: 58
The BT picture you posted gives the IP profile not the sync speed
g3uiss
By taking the ip privilege from the btw report as attached and applying the .967 factor. This also ties with an earlier support ticket that confirmed a similar line speed.
It's not a major issue I was interested in why there's a difference.
Fixes: 58
My reply #1 explained the difference
g3uiss
I won't comment further.
Tony
