Profile defaulted to 888 / 8,517... again?
aj007
Hi guys and gals,
Third time this has happened, I'm not really sure what's going on. It seems everytime the line profile gets adjusted to 15000+, it eventually goes back to 8000 or so. What's going on?
Cheers Smiley
Uptime: 7 days, 4:11:18
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 8,517
Data Transferred (Sent/Received) [GB/GB]: 2.79 / 57.40
Output Power (Up/Down) [dBm]: 5.0 / 0.0
Line Attenuation (Up/Down) [dB]: 12.7 / 26.0
SN Margin (Up/Down) [dB]: 8.9 / 15.7
Loss of Framing (Local/Remote): 61 / 0
Loss of Signal (Local/Remote): 7 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 984,996 / 392
FEC Errors (Up/Down): 39,311 / 469,246,643
CRC Errors (Up/Down): 4,037,862 / 36,620,463
HEC Errors (Up/Down): 1,363,450 / 18,619,659
Fixes: 60
Re: Profile defaulted to 888 / 8,517... again?
Just look at your errors - that is what is going on
You need to find out the reason and if it is on your side of the test socket fix it and if it is on the exchange socket raise a fault
aj007
How will I know if it's on my side or not?
Fixes: 60
Assuming you have a master socket with a removable faceplate
Remove the lower half and plug the router and phone via a filter to the test socket behind it then watch the errors
There is a video explaining it linked in this post http://community.plus.net/forum/index.php/topic,96155.0.html
Fixes: 36
@aj007
If it's easier for you to do we can do tests from here with the router in and also out of the test socket, any changes in the number of errors or the way the line is performing can help us locate a fault for you.
 Adam Walker
aj007
How long should I leave the router on till posting stats?
aj007
Sorry for the double post, thought I'd throw some stats up:
Uptime: 0 days, 3:02:58
Bandwidth (Up/Down) [kbps/kbps]: 888 / 8,592
Data Transferred (Sent/Received) [MB/GB]: 100.04 / 2.19
Output Power (Up/Down) [dBm]: 4.7 / 0.0
SN Margin (Up/Down) [dB]: 9.3 / 15.4
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 15 / 0
FEC Errors (Up/Down): 1,066 / 318
CRC Errors (Up/Down): 1 / 1
HEC Errors (Up/Down): 0 / 2
I'm not sure if interleaving is on for our line, would that help with the errors?
Fixes: 60
interleaving is already on
It certainly looks better in your test socket although your speeds have not increased, I'd suggest running through our faults wizard at http://faults.plus.net and run through the checks and we'll take a closer look at this.
aj007
Will do, thanks Smiley
