Profile defaulted to 888 / 8,517... again?
- Profile defaulted to 888 / 8,517... again?
24-04-2013 4:01 PM
Third time this has happened, I'm not really sure what's going on. It seems everytime the line profile gets adjusted to 15000+, it eventually goes back to 8000 or so. What's going on?
Cheers
Uptime: 7 days, 4:11:18
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 8,517
Data Transferred (Sent/Received) [GB/GB]: 2.79 / 57.40
Output Power (Up/Down) [dBm]: 5.0 / 0.0
Line Attenuation (Up/Down) [dB]: 12.7 / 26.0
SN Margin (Up/Down) [dB]: 8.9 / 15.7
Loss of Framing (Local/Remote): 61 / 0
Loss of Signal (Local/Remote): 7 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 984,996 / 392
FEC Errors (Up/Down): 39,311 / 469,246,643
CRC Errors (Up/Down): 4,037,862 / 36,620,463
HEC Errors (Up/Down): 1,363,450 / 18,619,659
Re: Profile defaulted to 888 / 8,517... again?
24-04-2013 4:06 PM
You need to find out the reason and if it is on your side of the test socket fix it and if it is on the exchange socket raise a fault
24-04-2013 4:07 PM
24-04-2013 4:11 PM
Remove the lower half and plug the router and phone via a filter to the test socket behind it then watch the errors
There is a video explaining it linked in this post http://community.plus.net/forum/index.php/topic,96155.0.html
25-04-2013 8:22 AM
If it's easier for you to do we can do tests from here with the router in and also out of the test socket, any changes in the number of errors or the way the line is performing can help us locate a fault for you.
25-04-2013 1:02 PM
25-04-2013 1:27 PM
Uptime: 0 days, 3:02:58
Bandwidth (Up/Down) [kbps/kbps]: 888 / 8,592
Data Transferred (Sent/Received) [MB/GB]: 100.04 / 2.19
Output Power (Up/Down) [dBm]: 4.7 / 0.0
SN Margin (Up/Down) [dB]: 9.3 / 15.4
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 15 / 0
FEC Errors (Up/Down): 1,066 / 318
CRC Errors (Up/Down): 1 / 1
HEC Errors (Up/Down): 0 / 2
I'm not sure if interleaving is on for our line, would that help with the errors?
25-04-2013 1:32 PM
25-04-2013 3:17 PM
25-04-2013 5:56 PM
