Profile Incorrect
GeordieMark
Profile Incorrect
Afternoon guys,
I can't imagine this is anything to worry about, but I've noticed my BT ip profile is less than what I'm syncing at.
BT IP profile shows
 Download speedachieved during the test was - 4.68 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 4.94 Mbps
However line is synced at 5.6Mbps, and my Plusnet account shows
Estimated line speed:
Current line speed:
4.9 Mb
I'm thinking maybe this is why I'm not seeing anywhere near the 5.6Meg sync rate on speed test? (wired)
Thanks in advance.
Mark
PeeGee
Re: Profile Incorrect
Your profile will be 88.2% of the sync speed.
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Plusnet Staff
Plusnet Staff
Fixes: 5
Given your line length, your connecting at exactly that rate I would expect. Your profiles are all matching up correctly too.
Chris Pettitt
Cloud Environments Engineer
GeordieMark
Thanks for the reply Chris, I was just worried I was capped at the 4.9 profile BT have me on as I never see past 5Meg throughput which i'd have expected as I'm syncing at 5.6Meg.
