Profile Check
- Re: Profile Check
Profile Check
31-08-2013 11:51 PM
please can you check what speed my profile is on. Currently connected at 16mb but believe profile is stuck at 4mb (had an issue with a adsl filter which had lowered sync speed temporarily).
With thanks
Mark
With thanks
Mark
Message 1 of 7
(1,748 Views)
6 REPLIES 6
Re: Profile Check
01-09-2013 7:36 AM
Your Plusnet profile can be found by looking at the "Current line speed" here - https://portal.plus.net/my.html?action=data_transfer_speed
Your BT profile can be found by running the following test - http://www.speedtest.btwholesale.com/
After the initial speed test, hit the "[Further Diagnostics]" button, enter your phone number, then "[Run Diagnostic Test]".
After a minute or two, it will display various results including "IP Profile for your line is..."
Message 2 of 7
(859 Views)
Re: Profile Check
01-09-2013 10:18 AM
Thanks, could you change my profile as the results are as follows (leaving fastpath enabled):
Plusnet:
Telephone number:
Phone exchange:
LITTLEHAMPTON
Estimated line speed:
12Mb (This may vary between 9Mb and 15.5Mb) - Checked on 2013-07-25 10:59:37
Current line speed:
4.4 Mb
BT:
Down 4.55
Up 1.06
Ping 33.63
Router Stats:
xDSL linestate up (ITU-T G.992.5; downstream: 15965 kbit/s, upstream: 1276 kbit/s; output Power Down: 19.3 dBm, Up: 12.6 dBm; line Attenuation Down: 23.5 dB, Up: 13.3 dB; snr Margin Down: 3.1 dB, Up: 10.7 dB)
Plusnet:
Telephone number:
Phone exchange:
LITTLEHAMPTON
Current line speed:
4.4 Mb
BT:
Down 4.55
Up 1.06
Ping 33.63
Router Stats:
Message 3 of 7
(859 Views)
Re: Profile Check
01-09-2013 12:24 PM
But what does the BT profile say ?
The BT details you listed above only show the initial test result, you need to follow the "[Further Diagnostics]" described in Reply #1
Message 4 of 7
(859 Views)
Re: Profile Check
01-09-2013 3:56 PM
Sorry im used to sky fibre so been a while. The further diagnostics showed everything fine and dandy but still only the 4meg down. Guess its the DLM I need to wait for. Previously with BE and the sky fibre so first time with ADSL DLM, used to being able to play with line as much as I liked without it being so fussy.
Ill just wait and see what happens.
Message 5 of 7
(859 Views)
Re: Profile Check
01-09-2013 4:33 PM
If the BT profile remains stuck after a couple of days, then try a modem reboot during daylight hours.
If it is still stuck after that, then come back to this thread and ask the staff to perform a line reset.
Message 6 of 7
(859 Views)
Re: Profile Check
02-09-2013 1:43 PM
Looks like both our side and BTs are currently set to 14400, please let us know if that's not correct?
Message 7 of 7
(859 Views)
