Problems
- Problems
Problems
20-03-2011 4:32 PM
Internet is like treacle although my connect speed is fine and I've low CRC errors.
mtr to news.bbc.co.uk shows high losses within PN
and here's the community:
Keys: Help Display mode Restart statistics Order of fields quit
Packets Pings
Host Loss% Snt Last Avg Best Wrst StDev
1. 192.168.0.66 0.0% 107 91.4 68.5 6.6 256.1 34.3
2. lo0-central1.pcl-ag04.plus.net 2.8% 107 30.6 63.2 28.9 272.9 42.7
3. gi1-10-411.pcl-gw01.plus.net 15.9% 107 44.1 67.9 28.7 308.2 49.1
4. po4.pcl-gw02.plus.net 12.1% 107 203.0 60.4 29.3 224.2 41.7
5. po5.thn-gw02.plus.net 11.2% 107 102.9 56.5 28.5 229.8 39.4
6. rt0.thdo.bbc.co.uk 9.3% 107 62.1 53.6 28.7 209.8 32.9
7. 212.58.238.149 8.5% 106 29.7 55.6 29.1 232.3 41.1
8. te12-1.hsw1.cwwtf.bbc.co.uk 7.5% 106 31.1 52.6 29.7 238.7 36.4
9. 212.58.255.12 5.7% 106 51.0 56.6 29.9 201.7 34.8
10. bbc-vip004.cwwtf.bbc.co.uk 8.5% 106 30.7 52.0 29.6 217.5 33.0
Packets Pings
1. 192.168.0.66 0.0% 106 50.5 53.4 2.2 263.7 42.1
2. lo0-central1.pcl-ag04.plus.net 0.0% 106 28.8 44.5 28.4 334.8 44.1
3. gi1-10-411.pcl-gw01.plus.net 5.7% 106 29.1 49.6 28.4 501.8 65.9
4. po5.ptn-gw01.plus.net 5.7% 106 43.8 54.7 40.4 229.8 34.2
5. gi3-0.pih-cr1.plus.net 6.7% 105 41.0 51.4 40.0 429.7 44.1
6. if25.pih-lb03.plus.net 3.8% 105 54.0 57.8 39.8 214.5 35.9
7. community.plus.net 7.6% 105 40.5 51.1 39.7 240.6 30.8
Message 1 of 8
(1,215 Views)
7 REPLIES 7
Re: Problems
20-03-2011 5:31 PM
I am a samknows/ofcom monitor, these are my load times this year, ADSL2: 14000 profile
Dont know what happened beginning of March
Message 2 of 8
(574 Views)
Re: Problems
20-03-2011 5:53 PM
Quote from: SteveA 1. 192.168.0.66 0.0% 107 91.4 68.5 6.6 256.1 34.3
It does seem like there is a problem on Plusnet's network... but before that, there appears to be a big problem on your own.
68.5ms average ping time between your computer and your router? Best 6.6ms?
Here's mine
1. h254.home.com 0.0% 113 0.8 0.5 0.5 1.4 0.1
2. lo0-central3.pcl-ag07.plus.net 0.0% 113 18.9 114.9 11.0 8651. 811.2
3. gi7-11-731.pcl-gw01.plus.net 0.0% 113 15.4 55.4 10.1 290.1 61.2
4. po4.pcl-gw02.plus.net 0.0% 113 162.0 48.5 11.4 224.1 51.8
5. po5.thn-gw02.plus.net 0.0% 113 15.1 44.6 11.1 263.8 47.1
6. rt0.thdo.bbc.co.uk 0.0% 113 16.8 60.1 10.8 333.7 68.1
7. 212.58.238.149 0.0% 112 13.6 45.8 11.2 226.7 45.8
8. 212.58.239.62 0.9% 112 66.3 38.1 11.4 222.8 35.4
9. 212.58.251.44 0.0% 112 13.5 39.5 10.9 209.1 39.0
10. bbc-vip102.telhc.bbc.co.uk 1.8% 112 23.6 36.5 11.0 154.7 32.4
As you can see, compared to my LAN your worst case latency is 18293% of my worse case latency (my worst case being 100%).
Message 3 of 8
(574 Views)
Re: Problems
20-03-2011 6:30 PM
Quote from: fourfourdevon
Wireless connection - sometimes does that. Can't say that I'm too impressed with the TG585 v7
But then looking at your stats the hop out to PN on yours isn't too hot
Message 4 of 8
(575 Views)
Re: Problems
20-03-2011 8:57 PM
Ah spurious result I think, as I learned how to copy the output of rtm without causing it to quit.
I just left it running for an hour our two and got
That seems fine to me.
As for your own results, even with wireless they look incredibly poor to me. Can you connect by cable and do the test again?
1. h254.home.com 0.0% 10149 0.5 0.4 0.4 11.8 0.2
2. lo0-central3.pcl-ag07.plus.net 0.0% 10149 18.8 26.7 10.4 254.5 29.0
3. gi7-11-731.pcl-gw01.plus.net 0.0% 10148 30.9 36.4 9.9 392.8 46.3
4. po4.pcl-gw02.plus.net 0.0% 10148 111.1 30.2 10.2 327.4 37.8
5. po5.thn-gw02.plus.net 0.0% 10148 26.3 30.1 10.2 350.7 38.0
6. rt0.thdo.bbc.co.uk 0.2% 10148 22.2 37.6 10.2 500.4 51.4
7. 212.58.238.149 0.1% 10148 15.4 27.7 10.2 393.6 33.1
8. 212.58.239.62 0.0% 10148 61.7 25.7 10.1 254.3 29.7
9. 212.58.251.44 0.1% 10148 18.7 26.5 10.2 259.6 29.8
10. bbc-vip101.telhc.bbc.co.uk 0.1% 10148 39.8 25.8 10.1 255.1 29.3
Message 5 of 8
(575 Views)
Re: Problems
20-03-2011 9:38 PM
I'm concerned about the % loss inside PN not about the occasional slow packet on my internal network
Message 6 of 8
(575 Views)
Re: Problems
20-03-2011 9:41 PM
I understand, but I still think there is a problem with your currently local connection, and unless that's resolved how can you be sure the packet loss is the fault of Plusnet?
I would always try to use a wired connection when diagnosing network issues.
Message 7 of 8
(575 Views)
Re: Problems
21-03-2011 5:08 PM
my version of MTR seems to be giving odd timings as a pinging my router for 100 packets shows:
but mtr shows:
It looks like rebooting the router. which got me onto a different gateway seems to have solved the problem.
100 packets transmitted, 100 received, 0% packet loss, time 99049ms
rtt min/avg/max/mdev = 0.619/0.707/1.733/0.145 ms
but mtr shows:
1. 192.168.0.66 0.0% 101 94.2 43.3 3.6 95.4 27.6
Message 8 of 8
(575 Views)
