Problems with xbox live connection
kcmiles
I get the following error on my router when it tries to connect to xbox live. I have also had problems connecting to SKY. My internet seems to keep dropping out.
This is the error/security warning on my router events log.
FIREWALL icmp check (1 of 6): Protocol: ICMP Src ip: 65.55.42.131 Dst ip: 80.189.236.162 Type: Destination Unreachable Code: Port Unreacheable
The 65.55 ISP is microsoft, the 80.189 is Plusnet.
Thanks for any advice.
TORPC
Re: Problems with xbox live connection
Have you seen or tried
http://npr.me.uk/upnp.html
Hmm did this just start yesterday? I was having issues with the dashboard not loading however netflix and loved in were both loading and streaming fine and as I wasn't playing a game I didn't investigate!
What's the console?
I'm xbone with the beta update
Update: mine is working now with the update that was pushed overnight
Plusnet Staff
Plusnet Staff
Fixes: 5
Please let us know if the problem continues following the update that was pushed out overnight.
Chris Pettitt
Cloud Environments Engineer
