Problems with my broadband
- Problems with my broadband
- « Previous
- 1
- 2
- Next »
Re: Problems with my broadband
24-07-2008 9:39 AM
Normally you do it online through the member centre, but you'll probably have to work through the online tips, diagnostics etc. first that will repeat what you've recorded here.
24-07-2008 9:45 AM
You just need to go through http://faults.plus.net and answer those questions.
24-07-2008 9:46 AM
24-07-2008 1:31 PM
have looked at your connection logs and can see that your connection is regularly dropping which will cause the equipment at the telephone exchange to think that your line is unstable and in turn lower your BRAS or speed profile and adjust your line accordingly. If you solve the intermittent connection problem you will simultaneously solve your speed problem. An intermittent connection can be caused either by a line fault but it may also be caused by an internal wiring issue or problem with your broadband equipment. Due to this I would advise you to make sure that your modem/router is connected to the master telephone point on your telephone line, to change over your micro filter for an alternative and to remove all other devices from your line (telephones/fax machines etc) and monitor the line for stability. Once the stability of your line returns your speed will return within 72 hours as your speed profile returns to normal. If you think you have a fault you can investigate further by using our Fault Checker. This can be found at http://faults.plus.net/ and you can also use this tool to raise a fault with us if necessary. Should you have any further questions please do not hesitate to contact us.
This has sort of sent me mental....its like no one from bt or plusnet seem to want to actually fix the problem! I told them everything, and even copied in a link to this page...and they wanna fob me off by telling me its my friggin filter!!!....arrrrr!! I have tried millions of filters, routers, modems and still no fix!
Can someone help me with what i can do next?
24-07-2008 1:34 PM
What's happened here is that our faults checker has noticed that your exchange is showing "red" for congestion. Basically, you've got what appears to be an intermittent connection problem, which is causing your poor sync speeds and subsequently poor throughput.
Could you possibly reraise your connection problem as an intermittent one?
I'm sorry to be a pain.
24-07-2008 1:38 PM
Cheers mush!
27-07-2008 3:49 PM
I'll buy the guy who manages to fix this problem a crate of beer! Until then its the world slowest 3g connection for me!
28-07-2008 9:13 AM
If the test socket figures are better, then you may have a wiring issue with any extensions running off the master (even though you may not be using them to plug in your router.)
If no difference - then you will most likely have a problem with BT's external wiring.
28-07-2008 9:38 AM
Yay!
28-07-2008 10:34 AM
28-07-2008 10:47 AM
- « Previous
- 1
- 2
- Next »
