Problems with ip cameras - wireless?
- Re: Problems with ip cameras - wireless?
02-05-2014 8:42 AM
This is the extent of my knowledge/observations but is this down to the router? If so, is there a better router to use to gain a better wireless signal? Does anyone know of a good Netgear router to use with Fibreoptic? I appreciate any advice or suggestions as I'm fed up with resetting the cameras every time the signal is losta nd they get a different ip which then has to be entered into the camera & server software - not to mention the unreliability of the cameras every time I leave the house. I do realise that the lameras are at the lower end of the price range but surely they can't all be rubbish when they were previously OK when I was on old fashioned broadband.
Katie
02-05-2014 12:19 PM
Did you ever resolve this?
02-05-2014 12:40 PM
Katie
dick:quote
02-05-2014 2:25 PM
Katie
02-05-2014 2:32 PM
02-05-2014 4:21 PM
@Katie
Have you tried a different wireless channel
What steps have you already tried (save repeating & guess work)
02-05-2014 4:31 PM
My router is connected to the main box which is in the office and the signal up there is really good. However, the ip cameras which are 3 upstairs and 2 downstairs lose their signal at the same time - sometimes 1 or 2 and sometimes 3 or all 5 of them. This suggests to me that there a definite drop in the wireless signal. I was loathe to spend yet another £100 on a new router but it seems that is what is needed to get a constant signal.
Kar=tie
02-05-2014 4:50 PM
Quote from: katie I could surf the net & do downloads OK but the cameras kept going off when the signal dropped out.
Katie,
An off the wall thought... is your router WiFi channel setting set to AUTO or MANUAL?
I have observed WiFi clients not "following" a SSID changing its channel when working in auto mode. I suggest that this is worth confirming and if in AUTO try operating it in MANUAL and see if the problem goes away.
02-05-2014 5:22 PM
Katie
02-05-2014 5:37 PM
It could be caused by REIN
Try turning off all electrical devices
Then turn them on one at a time to see if any interferes with the WiFi signal
I have even known Laptop power packs / microwaves / fridge/freezers / C/H Boilers & much more be culprits for knocking out the WiFi signal
02-05-2014 6:35 PM
02-05-2014 9:07 PM
Katie
03-05-2014 1:25 AM
10-05-2014 3:19 PM
Katie
