Problems with gateway checker
Fixes: 10
http://usertools.plus.net/@gateway is currently telling me
Sorry, the tool currently could not identify your gateway; this does not mean that anything is wrong with your connection.
It should say something like
You are currently connected to the gateway known as ptn-ag03.
I've reported this on the usergroup forums (the checker runs on their server) and they've commented that usually if there is a problem there are reports on these forums.
Could everyone check if it is working for them please, and if it doesn't give the correct result post the output from a tracert to ntp.plus.net. E.g.
C:\Users\John>tracert ntp.plus.net
Tracing route to ntp.plus.net [212.159.6.9]
over a maximum of 30 hops:
  1    4 ms    1 ms    1 ms  dg834 [192.168.0.1]
  2    12 ms    11 ms    17 ms  lo0-homesurf.pcl-ag01.plus.net [195.166.128.28]
  3    73 ms    11 ms    11 ms  84.92.5.64
  4    11 ms    11 ms    11 ms  vl63.pcl-lb01.plus.net [212.159.2.252]
  5    12 ms    12 ms    12 ms  cdns01.plus.net [212.159.6.9]
Trace complete.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
pierre_pierre
Re: Problems with gateway checker
gateway check ok
You are currently connected to the gateway known as ptn-ag02.
This is located in Telehouse North.
but a tad bit slow
Tracing route to ntp.plus.net [212.159.13.50]
 1    16 ms    99 ms    99 ms  dsldevice.lan [192.168.1.254]
 2    32 ms    23 ms    24 ms  lo0-central2.ptn-ag02.plus.net [195.166.128.206]
 3  1316 ms    22 ms    22 ms  gi2-12-221.ptn-gw01.plus.net [84.92.5.145]
 4    22 ms    22 ms    22 ms  vl55.ptn-lb01.plus.net [212.159.2.124]
 5    22 ms    21 ms    21 ms  cdns02.plus.net [212.159.13.50]
Trace complete.
Fixes: 96
Hi jelv,
Looks like there is a problem with some of the rDNS entries when tracing back to a customer. Because the gateway checker is reliant on a *reverse* trace then tracing out from your machine doesn't tell us much.
You're much better off running a reverse traceroute using something like this.
e.g.
If I browse to the gateway checker I am also getting:
[quote author="Gateway checker"]Sorry, the tool currently could not identify your gateway; this does not mean that anything is wrong with your connection
If I trace to my machine from work I get:
1 1 ms 1 ms 1 ms fa0-7.pih-cr1.plus.net [84.93.216.84]
2 1 ms 1 ms 1 ms vl421.pih-gw3.plus.net [212.159.1.171]
3 54 ms 14 ms 14 ms gi1-1.ptn-gw01.plus.net [212.159.1.178]
4 15 ms 14 ms 14 ms po6.thn-gw1.plus.net [212.159.1.136]
5 11 ms 11 ms 11 ms vl303.thn-gw1.plus.net [84.92.3.177]  <--- this *won't* work!
6 my.router
If I trace to my parent's machine I get:
1 1 ms 1 ms 1 ms gi4-46.ptp-cr01.plus.net [84.93.216.81]
2 7 ms 7 ms 7 ms gi1-22.pcl-gw01.plus.net [84.93.224.49]
3 7 ms 7 ms 7 ms te2-2.pte-gw1.plus.net [212.159.0.186]
4 12 ms 12 ms 12 ms vl22.thn-gw1.plus.net [212.159.4.3]
5 11 ms 8 ms 8 ms gi11-0-0-211.thn-ag2.plus.net [84.92.6.193] <--- this *will* work!
6 parents.router
Basically, the penultimate hop *back to you* needs to be named so that it contains a reference to the gateway you're connected to. If it doesn't, then the tool won't work. thn-ag2 is the name of one of our edge routers, whereas thn-gw1 isn't.
We'll be correcting the spurious DNS entries in due course. I've opened an internal problem to track the work (ref: 64354).
Fixes: 19
Works fine for me.... (central southern england)  Smiley
Fixes: 10
Bob,
Until this problem is resolved should you be posting service status announcements which contain
You can check which gateway you're connected to by visiting http://usertools.plus.net/@gateway.
Fixes: 96
Quote from: jelv
I think there's still value in including the link as it will still have worked for the majority and the error that's returned is concise enough where it doesn't.
Anyway, we've now checked and corrected the rDNS for all ERX virtual router links so the problem should be fixed.
Shout up if it does resurface or you've reason to believe it's still happening.
Apprentice
It's working for my maaf connection via PN  Smiley
  2    56 ms    57 ms    58 ms  lo1.pcl-ag05.plus.net [195.166.128.45]
  3    57 ms    57 ms    58 ms  unknown.plus.net [84.92.3.61]
  4    67 ms    66 ms    66 ms  gi5-8.ptp-cr01.plus.net [84.93.224.48]
  5    65 ms    66 ms    67 ms  vlan400.pih-gw3.plus.net [84.93.224.51]
  6    66 ms    66 ms    65 ms  if25.pih-lb03.plus.net [212.159.0.17]
  7    65 ms    66 ms    65 ms  www.madasafish.com [212.159.8.56]
Trace complete.
Fixes: 68
Thanks for confirmation.
David
David
