Problems with TP-Link TD-W9980 on ADSL
codemonkey
My Netgear DGND3300 has packed up, so I bought a TP-Link TD-W9980 XDSL router/modem, thinking it would handy for when I eventually move to fibre-optic broadband.  However, I can't get it to connect.
I've tried the quick-start settings, picking ADSL/Plusnet, and I've tried entering the settings manually VPI=0, VCI=38, VC-Mux, PPoA/PPP & PAP/CHAP authentication.  No success either way.  The DSL light just keeps flashing.
I've left it on overnight, thinking it might be training.
From the Diagnostics page I get "test xDSL synchronisation fail"  so I guess it's  most likely settings.
I've searched through the forums and people do get this working with Plusnet  ADSL.  Anyone got any clues what I might have done incorrectly?  Have I bought the wrong router? Is it a dud?
From the logs I get a lot of this:
1970-01-01 00:07:35 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0xc9433fa>]
1970-01-01 00:07:36 [5] DSL: xDSL Handshake!!
1970-01-01 00:07:38 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0xc9433fa>]
1970-01-01 00:07:41 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0xc9433fa>]
1970-01-01 00:07:42 [5] DSL: xDSL Training!!
1970-01-01 00:07:49 [3] PPP: ppp0 User request
1970-01-01 00:07:54 [5] DSL: xDSL Leave Showtime!!
1970-01-01 00:07:54 [5] DSL: xDSL Ready!!
1970-01-01 00:07:54 [5] DSL: xDSL Handshake!!
1970-01-01 00:07:54 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x67f40a50>]
1970-01-01 00:07:57 [5] DSL: xDSL Training!!
1970-01-01 00:07:57 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x67f40a50>]
1970-01-01 00:07:59 [5] DSL: xDSL Leave Showtime!!
1970-01-01 00:08:00 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x67f40a50>]
1970-01-01 00:08:02 [5] DSL: xDSL Ready!!
1970-01-01 00:08:03 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x67f40a50>]
1970-01-01 00:08:05 [5] DSL: xDSL Handshake!!
1970-01-01 00:08:06 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x67f40a50>]
1970-01-01 00:08:09 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x67f40a50>]
1970-01-01 00:08:11 [5] DSL: xDSL Training!!
1970-01-01 00:08:12 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x67f40a50>]
1970-01-01 00:08:13 [5] DSL: xDSL Leave Showtime!!
1970-01-01 00:08:15 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x67f40a50>]
1970-01-01 00:08:17 [5] DSL: xDSL Ready!!
1970-01-01 00:08:18 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x67f40a50>]
1970-01-01 00:08:20 [5] DSL: xDSL Handshake!!
1970-01-01 00:08:21 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x67f40a50>]
1970-01-01 00:08:29 [3] PPP: ppp0 User request
1970-01-01 00:08:35 [5] DSL: xDSL Training!!
1970-01-01 00:08:35 [5] DSL: xDSL Leave Showtime!!
1970-01-01 00:08:35 [5] DSL: xDSL Ready!!
1970-01-01 00:08:35 [5] DSL: xDSL Handshake!!
1970-01-01 00:08:35 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x1e862b4c>]
1970-01-01 00:08:38 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x1e862b4c>]
1970-01-01 00:08:40 [5] DSL: xDSL Training!!
1970-01-01 00:08:41 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x1e862b4c>]
1970-01-01 00:08:42 [5] DSL: xDSL Leave Showtime!!
1970-01-01 00:08:44 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x1e862b4c>]
1970-01-01 00:08:46 [5] DSL: xDSL Ready!!
1970-01-01 00:08:47 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x1e862b4c>]
1970-01-01 00:08:49 [5] DSL: xDSL Handshake!!
1970-01-01 00:08:50 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x1e862b4c>]
1970-01-01 00:08:53 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x1e862b4c>]
1970-01-01 00:08:55 [5] DSL: xDSL Training!!
1970-01-01 00:08:56 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x1e862b4c>]
1970-01-01 00:08:57 [5] DSL: xDSL Leave Showtime!!
1970-01-01 00:08:59 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x1e862b4c>]
1970-01-01 00:09:00 [5] DSL: xDSL Ready!!
1970-01-01 00:09:02 [6] PPP: ppp0 sent [LCP ConfReq id=0x1 <mru 1492> <magic 0x1e862b4c>]
1970-01-01 00:09:03 [5] DSL: xDSL Handshake!!
1970-01-01 00:09:10 [3] PPP: ppp0 User request
1970-01-01 00:09:15 [5] DSL: xDSL Training!!
1970-01-01 00:09:15 [5] DSL: xDSL Leave Showtime!!
cedlor
Re: Problems with TP-Link TD-W9980 on ADSL
Have you entered your plusnet logon correctly    username@plusdsl.net  and the password you used at plusnet registration
codemonkey
Yep, I have used my @plusdsl.net login name, and I've checked my p/word is correct a few times.  Currently using a back-up router.  All the settings appear the same between this, my new TD-W9980 and my netgear DGND3300.
cedlor
Did you select the correct mode  see here  Most of this is for fibre so not all relevant
http://wiki.kitz.co.uk/index.php/TD-W9980_QuickSetup
codemonkey
I did.  I'll plug in back in and get a screenshot...
codemonkey
See attached pdf for screenshots of setup screens, plus log file extract which doesn't show any changes.  I also did a factory reset on the TDW9980 and started setup again.  Still no joy.
As far as I can tell, I have all the settings the same between routers, and also username/password. Because I've been using a different router as a backup, I did a factory reset on that then plugged in my own settings.  That works fine, so I'm confident I know my user name and password.
I'm coming to the conclusion that either the router is faulty, or its a PoS that I no longer want to own.  Either way I'm about to send it back.
cedlor
You should edit out your user name
minkey
What do you have on your DSL Settings page.
It should say:
DSL Modulation Type: Auto Sync-up
Annex Type:A/B/L/M
Tick the two check boxes.
codemonkey
Hi minkey.
Yes, that's what I have.
Fixes: 22
You could try explicitly selecting whichever of ADSL2+, ADSL2 or G.dmt (ADSL1) is most appropriate for your line. Or the one you got could be a dud.
codemonkey
Ejs,
yep, tried all that, too.  Been through all the options one at a time, in every combo I can work out.
I've requested an RMA, so it'll be going back tomorrow or Wednesday.  See if mine is a dud.
Thanks for everyone's comments.  At least I've been thinking on the right lines.
Cheers.
