Problems with Port Forwarding?
HoboWithAShotgu
Hello, I seem to have trouble with forwarding ports for a few games (GGPO and Guilty Gear XX: Reload). My ports seem to be set up properly in my router page, but the ports themselves seem to be closed, no matter what I try. I also have both applications running while testing the ports. I've had to enable DMZ and Game Mode temporarily for both games to work for the time being. Windows Firewall seems to be working fine, has the correct permissions ticked.
Any advice would be great, thanks.
TORPC
Re: Problems with Port Forwarding?
Fixes: 6
That does the same a DMZ which is now in the routers GUI.
Plusnet Staff
Plusnet Staff
Fixes: 5
Which router are you using? Is it the Technicolor 582n.
Chris Pettitt
Cloud Environments Engineer
