Problems with BT Speedtester
- Re: Problems with BT Speedtester
04-09-2010 11:30 AM
Frequently when using the above after verification of my user name and just as the test is to start I get this message:
Exception: connection refused: connect.
The test then runs to the stage where it says:
No. of threads are 16! Progress 96%
and that's as far as it goes. I am able to run another test immediately afterwards, sometimes successfully and sometimes with the result as described above.
Has this happened to anyone else recently?
Message 1 of 6
(1,171 Views)
5 REPLIES 5
04-09-2010 11:36 AM
Me and I tried this link which seemed to work better http://217.32.105.42:50301/
Message 2 of 6
(468 Views)
04-09-2010 12:12 PM
Thanks Jim. Just tried it but of course it was less than an hour ago when I managed a successful test so I'll have to wait a while before trying it. I've added it to my favourites though.
Message 3 of 6
(468 Views)
04-09-2010 2:10 PM
It worked first time so let's hope that's solved the problem. Once again, many thanks Oldjim
Message 4 of 6
(468 Views)
04-09-2010 3:15 PM
I also had to update Java when this happened to me.
Message 5 of 6
(468 Views)
04-09-2010 3:26 PM
thanks for that link, Jim.
I've had a few problems with the BT speedchecker recently, too. What was more frustrating is that, even though a test was never succesfuly completed, on refreshing the page and trying again I was usually met with the 1 hour wait.
Your link worked first time with no gliches.
Cheers
Cheers
Forum Moderator and Customer
Message 6 of 6
(468 Views)
