Problems trying out PCLinuxOS
VileReynard
Fixes: 20
Re: Problems trying out PCLinuxOS
Of course you could always boot from a live copy of Ubuntu, and use this to make appropriate adjustments to your Wifi setup - including downloading any PCLinuxOS bits  Grin
artificer
good luck with your new piece of kit.  i hope it works for you.  have you tried connecting via ethernet cable, rather than wifi, or is that inconvenient?
waldron
I've been using ethernet to try to resolve the problems. But it meant moving the PC, monitor, keyboard etc into a bedroom on the floor to get close to the router (the master BT socket is the only one with broadband available). That's not a viable long term solution, hence the wifi requirement. Hopefully a PCI card which has linux drivers available will solve the problem.
Thanks to everyone for your help and suggestions.
grimme
It looks as thought it's found the WIFI card correctly  - but it hasn't setup the encryption. You might need to go into the control panel again and into reconfigure an existing connection - then add the WPA encryption requirement and the key.
I'm afraid I did take the easy option and changed the Mini-PCI card in the netbook I used to an Intel known detectable model.  Smiley
There's also a newer release candidate of SAM 2008 and that's based on PCLinuxOS, with additional software pre-loaded you might like to try.
waldron
I am pleased to say that I installed my new PCI card today and it worked perfectly first time with both Windows and PCLOS.
artificer
excellent news.:D  have a lot of fun with linux.
