Problems streaming You Tube
- Problems streaming You Tube
Re: Problems streaming You Tube
27-07-2009 4:03 PM
-- does buffer much slower than the earlier Cohen O2 performance but still faster than the player bit-rate. HOWEVER, both of the HD versions stutter a bit in IE8 because, I think, of the massive demands being made on my cpu. This is obviously nothing to do with Plusnet and is, I think, a feature of the Flash Player (WindowsMediaPlayer is using hardly any cpu compared with IE).
Hope this non-technical test is some use?
Chris
27-07-2009 4:27 PM
27-07-2009 5:10 PM
Quote from: jelv
Quote from: BlueRhizome Pausing allows the buffer bar to make progress. Unfortunately for me this does not improve the situation when viewing.
Did you wait until the video had fully buffered before starting to view it again?
Have you tried full screen?
Had not but now have. Same problem in both small and full screen.
27-07-2009 5:17 PM
Quote from: ChrisL I'm testing these youtube videos at the same time as streaming BBC radio at 192Kbps in WindowsMediaPlayer. The second one -- video
Chris
Possibly, as I have no problem watching these in RealPlayer (once downloaded and converted to AVI), whereas IE and Firefox are giving me grief. But there again, I am your ultimate layperson...
27-07-2009 10:08 PM
27-07-2009 10:20 PM
This leads me to the clear conclusion that there was an overall rate limit earlier this evening. This needs to be checked out
28-07-2009 12:09 AM
Quote from: orbrey Hmm, if it's fully buffered then it has to be either the software or the hardware on your PC and as other players work fine I'm going to have to say software. I guess you could try uninstalling and then reinstalling the flash player? Not sure what else I can suggest really but I'll have a think.
Hi Orbrey
I uninstalled FlashPlayer and installed the latest version yesterday.
Don't know if this can help with your diagnosis, but the situation is that I can watch the same clip twice with totally different outcomes, i.e. perfect HD stream in full screen / choppy frames and stuttering sound, even in ordinary quality and in small screen. This can happen even if I watch them within seconds of each other.
It seems, from what Oldjim is saying, that bandwidth rate is not consistent on YouTube streams. Could there be a fault somewhere, or are people simply experiencing software issues (or perhaps a bit of both)?
Bit of a headache I think!
30-07-2009 11:12 AM
I'm on unlimited, with a 7150 profile and was suffering buffering after about 2 seconds on
and then it was being slow...
30-07-2009 12:29 PM
However with regards to the stuttering in HD, I encountered this and found after some troubleshooting on the matter that if I drag the position slider to the beginning, even if it appears to be so already, it'll play smoothly (providing the video streams fast enough). I can only assume this is a problem with the youtube player or flash. Hopefully this might solve any stuttering issues you have with the HD videos.
30-07-2009 7:45 PM
Are Plusnet ever going to allow us to use YouTube as it's intended to be used? It's got to be something on their end as my mate's who're on different ISPs (Virgin, Zen and Be) can all stream the videos perfectly fine and without a problem.
It's not my PC either, that's more than capable of streaming and playing HD content.
30-07-2009 7:51 PM
09-08-2009 8:04 PM
09-08-2009 8:21 PM
09-08-2009 8:41 PM
09-08-2009 8:58 PM
