Problems getting worse
- Problems getting worse
11-01-2014 9:12 AM
So much for good honest yorkshire broadband
Problems getting worse shit speeds. Cant even get a web page up half the time with out problems snail speed
I'm on ADSL2+
1. Latency 60+ constantly
2. ^ D/S & U/S worse with plusnet than when i was with British Telecommunications
3. I can understand Gaming on any device does not take much D/S U/S but all's im getting is constant lag even downloading a game from uPlay 22GB is taking 36Hrs which in one word is shit
I always use a Ethernet connection for the best possible in game and browsing experience at my abode even when i had FTTC all's i got was problems constantly same as now
Random Disconnections
Disconnections when the home phone is used
I'm on ADSL2+
Message 1 of 4
(750 Views)
3 REPLIES 3
Re: Problems getting worse
11-01-2014 9:52 AM
So you need the line problem sorting
Have you raised a fault at https://faults.plus.net advising that the line drops when the phone is used
Message 2 of 4
(388 Views)
11-01-2014 2:56 PM
(Or with raising the fault with whoever provides your telephone service - particularly if you have noise/static on the line. You can do a Quiet Line test on 17070)
Message 3 of 4
(388 Views)
13-01-2014 11:31 AM
Hi BigTabs, thanks for raising the fault - hope you get an update and resolution soon.
Message 4 of 4
(388 Views)
