Problems Uploading
steed
Problems Uploading
For the past several days I have been having problems while trying to upload files. This seems to be an intermittent fault.
I have read some other posts on here and others have reported similar problems, but no mention about it on the service status page, or what is causing this, or when it will be fixed.
I cannot upload files to eBay, or upload using FTP, and neither upload image files using an app on my tablet.
Anyone with information on this problem?
The speed test shows 1Mb upload speed.
Fixes: 32
Re: Problems Uploading
Hi steed,
Diagnostics aren't pointing towards anything obvious.
Assuming like most you connect over WiFi, are you able to test over ethernet?
 Adam Walker
steed
There were problems using both Wifi and Ethernet.
I think it may have something to do with the problems posted in the "DNS/Routing issues for the last 36 hours" thread because I was also experiencing issues others have reported in that thread.
It seems to be working O.K. at the moment.
