Problem with landline only rings once
- Problem with landline only rings once
12-01-2012 2:34 PM
Any advice would be appreciated
![Sad Sad](/html/@5863905B9AC6EE4F2B28C1A2965ABC0C/images/emoticons/sad.gif)
Re: Problem with landline only rings once
12-01-2012 2:54 PM
12-01-2012 2:55 PM
12-01-2012 3:02 PM
Quote from: _Adam_Walker_ Our advice would be to try a different phone handset if you can get your hands on one. This would help rule out an issue with your phone. If that doesn't change anything then I'd be more inclined to think that it's a phone fault and as such would need to be dealt with by your phone provider (BT).
I could see that route going wrong. Phone engineer turns up, tries without the router plugged in, no fault found, tells you to report it to the broadband provider.
12-01-2012 3:09 PM
12-01-2012 3:10 PM
Quote from: wattsy When router is disconnected the phone also rings as normal.
![Roll_eyes Roll_eyes](/html/@BA2C29EA5D62B3049244C6EF0F36F4A9/images/emoticons/rolleyes.gif)
12-01-2012 3:24 PM
Quote from: wattsy The phone lead is in the test socket at the moment which solves the problem. When router is disconnected the phone also rings as normal.
Quote from: nozzer Happened to my line.... turned out to be a faulty line filter.
Think I agree with @nozzer. If the phone ring in all sockets when directly plugged into the sockets with no router plugged in and then stop ringer when plugged into the sockets via a filter then it will point to a faulty filter.
12-01-2012 3:28 PM
12-01-2012 6:04 PM
12-01-2012 6:27 PM
12-01-2012 7:01 PM
One thing that is not clear is what is your usual socket. Is it the master or an extension socket?
12-01-2012 7:38 PM
My usual socket is the master socket, I have three digital phones but of course only one plugged in to the phone line which is the master. So there isn't much internal wiring to go wrong is there??? So it can't be a problem with the router then???
Regards
12-01-2012 9:10 PM
12-01-2012 9:32 PM
Is it an Openreach-branded face plate? The newer ones include a ring capacitor.
12-01-2012 10:14 PM
I thank you for your advice.
