Problem with Safeguard
MW123
Since changing over to Plusnet I'm unable to deactivate the Safeguard - I have followed the instructions to the letter but I'm getting blocked from sites.
Can someone advise...
Thanks.
3 REPLIES 3
Fixes: 160
Re: Problem with Safeguard
A warm welcome to the forums. Which sites are you being blocked from accessing? This might not be a safe guarding issue, but rather one of some companies using out of date geolocation data thus believing you are outside of the UK.
Having followed the instructions, have you restarted the router and your device?
Fixes: 1,600
Hi there.
From looking at your account, Safeguard does seem to be turned off.
Mind PMing me a screenshot of the page you're seeing when you try to browse the web?
Fixes: 1,600
Thanks for the screenshot.
I think we've fixed this now. Can you factory reset your router by pushing a pin or paperclip into the reset hole at the back for 10 seconds please and let us know how it goes?
