Problem with Peer to Peer software SababaDC and DC++
TechBrigade
When i use the SababDC or DC++ to connect to any hub, i get connected successfully but within few seconds it gets disconnected.
I have enabled ports which are used by these applications.. but dont understand why i am getting disconnected?
I believe its to do with internal an external ip? Even putting settings in passive mode in DC++ wont help.
Any ideas? Is anyone using above applications? Can they please help me setup in settings?
Regards,
Rahul
