Problem with 'Create Broadband Your Way'
- Problem with 'Create Broadband Your Way'
03-01-2008 12:01 AM
I want to select Option 1 with 2Gbit plus the option of 1 extra G at £1 if I need it.
Any help would be apreciated.
Paulo
Re: Problem with 'Create Broadband Your Way'
03-01-2008 8:20 AM
Scroll down to where you see this image:
And click it
It should allow you to pick and choose as much allowance as you need
Scott
03-01-2008 10:58 AM
It gives the right options if you approach it as a 'new customer' but if you get there via a link in a 'referal email' it does not seem to work!!
Anyone help please.
Regards Paulo
03-01-2008 10:59 AM
Could you possibly show us the specific link that is presented in the email?
03-01-2008 11:05 AM
Here is the email referal link.
http://www.plus.net/myreferrals/new.html/1209356
Paulo
03-01-2008 11:18 AM
The link is actually still there. If you go to the Broadband Your Way page, and then scroll down just past where it says "Further Information about Broadband Your Way" there's a link called "No Broadband Your Way Option to suit you? Create your own!" which will allow you to specify the usage allowances.
03-01-2008 11:50 AM
If you use the email link it takes you to the Plusnet introduction page, clicking onto 'Broadband from £9.99 Go you get all the options (OK so far) then you click on the 'Create Broadband Your War' you get a drop down box (and this is where it goes wrong) that only gives you Opt 1, Opt 2, etc. If you then choose Opt 1 (for example) it takes you into ordering pages without the facility to choose various amounts od Gbit etc.
Please read this carefully and you will see the subtle difference that bypasses your ability to choose the right amount of Gbit.
Paulo.
03-01-2008 11:53 AM
I'm fully aware of what you are saying. I opened two separate pages, one with http://plus.net and the other with the link that you supplied and I was able to access the specifying GB link on both of them.
03-01-2008 11:57 AM
Adding onto James' comments, i understand what you are saying, their seems to be some strangeness happenings, ive noticed if you have no 'plus.net' cookies and you go to the link you have provided the 'create broadband your way' button is removed and you are left with 'switch your broadband'. If you have logged into the portal and then browse to the link you provided you are presented with the 'create broadband your way'.
How ever, i believe you are getting the 'switch your broadband' page where you woudl expect to see the 'create broadband your way'. You can still create package by looking for a link called: >No Broadband Your Way Option to suit you? Create your own!
Under the heading Further information about Broadband Your Way on this page: http://www.plus.net/residential/broadband/
If you still have problems, browse to: http://www.plus.net/residential/broadband/preconfigure.shtml
Apologises for the problems, i'll be sure to bring this up with the revelant people.
Dan.
03-01-2008 12:04 PM
03-01-2008 12:27 PM
Only if I delete cookies am I allowed to choose my usage options (ie Opt 1 + 2G) hooray, but as you move on to the 'buy' pages you go back into a loop that, if completed, shows that you are about to pay for the basic Opt 1 (£9.99) without the extra 2G that you requested.
Very frustrating!!
Paulo
03-01-2008 12:39 PM
Im not to sure whats happening on your end.
Can you please explain step by step the pages you go through and what you are selecting/clicking?
Sorry if we seem to be going back to square one but if their is a problem with our website we need to know exactly what you are doing and selecting to fix the issue.
Thanks,
03-01-2008 1:33 PM
Click Create BB Your Way GO.
Click Create BB now.
Remove usage (down to 2GB £10.74) Continue.
Choose Free setup and 1 port router Continue.
Choose No homephone.
Sign in as Existing customer(my friends username and password GO
This goes to member centre with Upgrade.
Now have 2 options either select from dropdown box or 'veiw all options'
View all options takes you back to original Plusnet page where you choose Create BB Your Way (back in loop)
If you select Opt 1 £9.99 from the dropdown box the Change
it takes you to the Hardware page.
Select Free setup and 1 port router Continue.
Select No Homephone continue and you get the invoice page showing £9.99 & postage, Pay Now so you are not getting the extra 2GB that you requested.
Paulo
03-01-2008 1:44 PM
Just put in your telephone number, and it should go alright.
Scott
03-01-2008 1:50 PM
Paulo, can you log in as them and then upgrade the account using this link?
https://portal.plus.net/upgrade_process.html?memberheader=upgrade
