Problem with Access TP-Link TD-W8951ND especially Wireless
- Problem with Access TP-Link TD-W8951ND especially ...
26-09-2015 7:07 PM
I have problems with the access of TP Link router TD-W8951ND
After the firmware updates the 1st time wizard did not offer plusnet as provider anymore but a simple hardcoded settings page.
I checked the info and seem to be able to connect without problems. This only works for Wired devices though. None of the wireless devices gets access to the internet
It says limited connection on the notebook. Did anyone come across this before?
pinging the router works when on wireless just the routing into the internet is not working.
edit: Problem Solved
Re: Problem with Access TP-Link TD-W8951ND especially Wireless
26-09-2015 7:28 PM
This is the firmware I am running on:
Firmware Version
5.0.0 Build 140306 Rel.28708
Here pictures of the settings(Onedrive Folder):
http://1drv.ms/1JvzrWn
also the WLAN statistics are a bid odd:
Transmit Statistics
Receive Statistics
Tx Frames Count 32,385
Rx Frames Count 86,191
Tx Errors Count 65
Rx Errors Count 15,373
Tx Drops Count 65
Rx Drops Count 15,373
26-09-2015 7:54 PM
26-09-2015 8:10 PM
Ethernet PC connection works like a charm
26-09-2015 8:41 PM
26-09-2015 10:00 PM
26-09-2015 10:06 PM
27-09-2015 9:08 AM
then maybe it is "just" a wifi problem. Are you near the router when you try? Tried a different channel?
There is quite a lot of setting up help in th manual.
This FAQ may also help http://www.tp-link.com/en/faq-722.html
Maybe change the security to None - just while you are testing,
27-09-2015 1:18 PM
just a little update on this. The devices all got confused on wifi access/dhcp/dns settings on the wireless. PlusNet Sagem router and TPLINK router were set to different DHCP server addresses(router ip) and the devices just couldn't get new proper settings.
27-09-2015 7:39 PM
