Problem recieving email
chip
we're in the process of getting plusnet broadband into the house I'm living in, but I've not been able to receive any email to the mailbox I've set up.
the error i get back is
The following recipient(s) cannot be reached: <matt@********.plus.com>. Reason: Domain <*********.plus.com> does not exist (DNS lookup failure)
can anyone help shed some light on it?
P.s. got a CSC problem number of: 53549
James
Re: Problem recieving email
Hiya,
I think Chris has got a fix for this.
I'll drop him a line (as he's gone home earlier) to see if he can sort things out for you.
Any chance of deleting the addy? Don't want it spammed from the outset.
James
I've removed it whilst there didn't seem to be a moderator about.
You just beat me to it Tongue
B.
chip
sorry, i edited it as well to put the stars in instead!
sorry
Fixes: 162
Unfortunately the fix I was using to get around these doesn't appear to be creating the mx records correctly. We have a problem currently being worked for this and I'll see what I can find out about it.
 Chris Parr
 Plusnet Staff
chip
ahhh ok, thanks
Fixes: 162
I'll try and get it pushed with some priority in the morning. Sorry about the hassle.
 Chris Parr
 Plusnet Staff
chip
thanks for the quick response from you guys.
chip
hey,
just wondering if there had been any updates on the email problem?
Fixes: 162
It's being worked on as a Priority Problem, it should be visible over on the website here.
Sorry I don't have more information at the moment, I'll update the problem when I can.
 Chris Parr
 Plusnet Staff
chip
cool, thanks for the update
chip
Thank you to you guys at plus net for getting the email problem fixed, as I can now recieve email's,
so thank you one again
