Problem everyday
kevinneilldsl
Problem everyday
Hi.. i'm having a problem this has become a daily problem now..my Speeds drop everyday! i Do PS3 internet connection tests every morning ( i only have a PS3) i use to have no problem atall was getting over 3.0  mbps. daily Gaming was Lag free downloading also Fast. Now my problem is this has been happening last 4 days now.. I Do PS3 connection test and I'm getting a poor 1.5 mbps sometimes 1.1 everything just seems slow.. anyways it takes about 2 restarts on my router for my speeds to be normal.. Can anyone help me fix this frustrating problem?
Thanks.. my PS3 internet connection Test is given me 3.1 mbps but was 1.8  mbps few hours ago! hopefully it stays that way!
Fixes: 5
Re: Problem everyday
Did you reboot the router between the 3.1 speed test and the 1.8 test?
Kelly Dorset
Broadband Service Manager
kevinneilldsl
Yeah.. just did another Test it's 3.3 now
kevinneilldsl
I've been downloading Tv shows at a fast speed now.. Just hope it stays 3.0 or above now
Fixes: 5
Need to know what gateway you are on when you are getting slow speeds.
Kelly Dorset
kevinneilldsl
Whats that? How do i find it?
Fixes: 5
http://usertools.plus.net/@gateway/
Kelly Dorset
kevinneilldsl
When i'm getting low speeds should i post my Gateway here?
Thanks.
Fixes: 5
Yeah. and if you reboot and get good speeds, the gateway you are now on.
Kelly Dorset
Fixes: 10
You don't need to reboot to change gateway. Go in to the router interface and tell it to disconnect. Leave it a moment or two and then reconnect. This method is STRONGLY recommended as there is no danger of the exchange seeing it as a unstable line and slowing your line to make it stable which is the risk if you just reboot.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 5
Good point Jelv.
Kelly Dorset
kevinneilldsl
Got cha jelv thanks
