Problem after moving to ADSL2+
- Problem after moving to ADSL2+
01-06-2010 11:34 AM
I've recently moved to to ADSL2+ after changing to Plusnet Extra. I have been with Plusnet for sometime and have always had a pretty stable connection. However, since changing to ADSL2+ I'm getting good speeds all day but something changes overnight & every morning the line is so slow that sometimes I can't even carry out a speed test. I find myself having to reboot the router every day to get the speed back to what it was before & everything is OK until the next morning.
I don't know much about the technical side of things but I have noticed a change in the router stats. The DSL path seems to switch between fast and interleaved but I get the problem whichever it is. These are the stats from this earlier this morning before I rebooted the router:
DSL Status: Connected
DSL Modulation Mode: MultiMode
DSL Path Mode: Fast
Downstream Rate: 15226 kbps
Upstream Rate: 446 kbps
Downstream Margin: 2147483647 db
Upstream Margin: 24 db
Downstream Line Attenuation: 20 db
Upstream Line Attenuation: 4.5 db
Downstream Transmit Power: 11 db
Upstream Transmit Power: 23 db
and these are the current stats:
DSL Path Mode: Fast
Downstream Margin: 9 db
Upstream Margin: 10 db
Upstream Line Attenuation: 5 db
Does anyone know what the problem is and how I can correct it? Do I need a new router? I have a Linksys WAG200G that is about 3 years old and is supposed to be compatible with ADSL2+.
DSL Path Mode: Fast
DSL Path Mode: Fast
Message 1 of 4
(6,700 Views)
3 REPLIES 3
Re: Problem after moving to ADSL2+
01-06-2010 1:26 PM
I've got the 200G and it does have a setting for ADSL2+ and ADSL2+ Annex M, not that I need it on ADSL.
http://en.wikipedia.org/wiki/Asymmetric_Digital_Subscriber_Line_2_Plus
Can't wait for someone to explain this Downstream Margin: 2147483647 db
Message 2 of 4
(413 Views)
01-06-2010 1:34 PM
If you search these forums you will find the answer Or I can tell you it's -1dB. 2147483647=7FFFFFFF in Hex which equal -1
Message 3 of 4
(413 Views)
01-06-2010 1:44 PM
After reading and putting my brain into gear after posting what I put above is wrong -1=FFFFFFFF but as the modem ignore the sign bit it become 7FFFFFFF which is the maximum positive number of 2147483647
Message 4 of 4
(413 Views)
