Problem, Modem not synchronising, need HELP!!
jim007
I've been having intermittent syncing problems and it's not  syncing at all.
I reset the modem and did a quick setup with the setting I got off the plusnet website, still no joy
Can someone please help?
Fixes: 51
Re: Problem, Modem not synchronising, need HELP!!
The CRT forum staff are not here on Sundays.. You could try chat or ringing support. However reporting a fault at http://faults.plus.net is probably the way to go. The troubleshooter should cope with the connection not being from your own line.
David
David
Fixes: 21
Hi Jim,
A warm welcome to the forums.
Is there a dial tone on the phone?
Is the phone line noisy?  Dial 17070 option 2.
If there is no dial tone or there is noise, then in the first instance raise a phone fault report.
Fixes: 46
I can see we've needed to book an engineer which looks to be appropriate.
Let us know if this continues to be a problem after the 1st.
 Adam Walker
