Pro add on worth it?
anniesboy
Im wondering if Pro Add On is worth it for me.
My wife and I are not gamers nor work from home,so mostly general browsing plus streaming together with up and downloading.
I realise the Add On is on a monthly contract .
My speed is poor at present always has been
Fixes: 77
Re: Pro add on worth it?
Hi anniesboy,
The add-on won't give you faster speeds, if those are an issue then I'd advise raising a fault with us: https://portal.plus.net/apps/kbdfaults
From you're described usage I don't think it would be much of an advantage but you could try it for a month and see how it goes.
 Adam Walker
Y2J
It wont really benefit you tbh mate, i had it for gaming years ago when it first come out worked well
