Pro Add-on with Fibre?
NatTheGooner
Hi
Is anyone using the Pro add on with their Fibre Optic package?
We could be moving over to Fibre next month and the Pro add on is great on our current ADSL package - games never worked very well until we paid the extra fiver.
I know that I shouldn't need it but I was wondering if anyone has it and what difference it made on fibre.
Fixes: 4
Re: Pro Add-on with Fibre?
Fibre unlimited gives titanium for gaming so you shouldn't need the pro addon, however if you have a long line, interleaving is more than likely to mess up your game because of the error correction. Anyway have a mooch through the plusnet traffic management guide.
http://www.plus.net/support/broadband/speed_guide/traffic_management.shtml
tokey
Im on the Fibre Unlimited package and have found the gaming experience to be fine without the Pro addon.
Pings can be single digit to UK servers even in peak evening hours but are typically between 20-35 for most games I've played hosted in Europe.
NorthEasterner
I've always had a 2 digit ping ms how'd you make it single?Huh
around 18ms when speed testing
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
NatTheGooner
Quote from: Tokey
Thanks for the replies
My ping on ADSL is good - about 18ms. A new cabinet has been installed about 70 meters away so I guess I'd be connected to that somehow.
What I'm trying to work out is if you could have the Pro Add On for free would you take it, or is there a downside to it on fibre - ie Interleaving, not sure what that is exactly...
Plusnet have told me that the Fibre package I want will cost me £7 pm more than my current 12meg ADSL, but if I then find I need to add the Pro option it then jumps to an extra £12 pm and that's not worth it just for a bit more speed.
Fixes: 5
You don't need Pro.
Kelly Dorset
Broadband Service Manager
NatTheGooner
OK, I don't need it, but if it was added what benefits would I see.
I'm guessing that Plusnet wouldn't sell a placebo to a fibre customer.
Fixes: 4
On the 'Unlimited' package, if you were running your connection at full capacity, AND you also happened to be playing an online game which had not yet been classified as having a gaming high priority profile, then you might notice an improvement in gaming response.
The 'Pro add-on', was intended for previous generation legacy products, many of which had evening rate limiting on certain protocols (such as P2P and FTP), the addition of the 'Pro add-on' effectively removed those product rate limitations.
On the current 'Unlimited' product, the add-on is largely irrelevant, as no traffic is shaped (speed limited) and the vast majority of traffic is correctly prioritized.
NatTheGooner
OK
That makes sense now.
There are benefits but if you're on Fibre it's not worth paying for.
Thanks for your help.
I'm going to post a question about the modem and router I'd get when moving to fibre, if anyone could help with that I'd appreciate it.
Thanks again.
flaminmoses
PN need to cap the number of users per gateway....or in other words get more gateways
Fixes: 4
Quote from: NatTheGooner
New question about modem and router is here - http://community.plus.net/forum/index.php/topic,117394
To avoid any confusion.
Fixes: 5
Quote from: flaminmoses
eh?
Kelly Dorset
NorthEasterner
Anyone want to respond to my post regarding pings ms?
Fixes: 4
No !,  how about starting your own thread about your new topic !  Crazy
NorthEasterner
I don't see why when its related to this topic  Roll eyes
