Pro Add On
- Pro Add On
Pro Add On
16-06-2012 9:16 PM
Just added the pro add on to my account but the speeds still remain slow for some reason as they was before i added it, surely i should see an increase in speeds during peak times with the pro add on?.
Message 1 of 4
(789 Views)
3 REPLIES 3
Re: Pro Add On
16-06-2012 9:37 PM
What exactly is running slow, is it a particular type of traffic?
Message 2 of 4
(363 Views)
Re: Pro Add On
16-06-2012 9:43 PM
Usenet.
Message 3 of 4
(363 Views)
Re: Pro Add On
18-06-2012 2:22 PM
I can see the add on is there and active and you're on the correct service offer, which usenet provider is it you're connecting to and which client? Just wondering if it'd be worth adding a few more threads to see if that improves the speed.
Message 4 of 4
(363 Views)
