Price issues and change in policy
- Price issues and change in policy
17-09-2007 9:56 PM
Re: Price issues and change in policy
17-09-2007 11:16 PM
18-09-2007 10:12 AM
When you signed up on your 'unlimited' product, looking at when this was, I'm guessing that this was probably on a 512Kbps product and hence we were able to offer that kind of product. the maximum that you could download in a month would be roughly 150GB. Now you're looikng at potentially 2400GB per month on a maxed connection (rough estimates). Because we are charged for capacity, we have to offer a realistic amount in our usage allowances and we allow you to download for 'free' during off peak times of the day. Feel free to have a read of our blueprint:
http://www.plus.net/support/broadband/quality_broadband/blueprint.shtml
Lots of information about Broadband Your Way:
http://www.plus.net/support/broadband/products/broadband_your_way/
Going back to your legal concern, I'm afraid that you don't have a case. Changes to terms and conditions were communicated out in (I believe) July 2005. Would you be able to use a scheduler to perform your larger downloads between midnight and 4pm on Premier or midnight and 8am on Broadband Your Way? You can download an awful lot during that time!
I do fully appreciate that our products, old or new may not appeal to everyone, but I would be hopeful that you would have a good look at our new product line and see if you feel that this would be applicable to you.
Feel free to drop me a line if you would like to discuss this further.
18-09-2007 10:22 AM
Actually usage didn't really become a factor until higher speeds came in and the way ISPs were charged changed.
18-09-2007 5:34 PM
My main concern is that my peak usage amount is less than the stated 20Gb restriction, yet I am having restrictions imposed at my inconvinience before the level is reached. Personally I don't come near the limit, but a user on my small home network has discovered the world of video streaming, and can download a lot of data in the peak hours of 4pm - 12am. Also for some reason this data registers as WEB data, not video streaming, so regardless of your usage restrictions after 13gb, its purpose is not being served since the usage type is incorrectly detected and therefore imposing restrictions on services that are not the main culprit. I fully understand that not all data can be correctly detected, but then to add extra restrictions based on a volatile detection mechanism seems flawed to me. If you decided that 17gb was the start of level 2 restrictions, I would be in full support of such restrictions.
19-09-2007 8:21 AM
In terms of what you download, this is irrelevant to us. The only reason we restrict P2P/Usenet is because it can be very bandwidth hungry, and will just take as much bandwidth as is available.
It is possible for traffic to be misidentified, depending on a number of factors including the program used, the port, the signature of that traffic, encryption and a whole host of other things. The actual amounts are verified though, so I can assure you that they are correct, and it is this with triggers management, not the type of traffic you use.
Your peak time allowance is 20GB, with level 1 management at 13GB, and level 2 at 17GB.
We have moved away from this method with the Broadband Your Way products, but as Premier is no longer sold I wouldn't expect there to be any changes to it at all.
19-09-2007 9:19 AM
*addition*
Just something I noticed whilst re-reading "We have moved away from this method with the Broadband Your Way products, but as Premier is no longer sold I wouldn't expect there to be any changes to it at all." - I thought plusnet strived to provide a reliable and quality service. Does this only apply to users on current plans?
19-09-2007 9:55 AM
19-09-2007 10:09 AM
When we changed the Premier product we emailed all customers to advise them of this change, giving the usual 30 days opt out.
As this was some time ago, it's possible that people will be unaware or have forgotten, but the product has been as it is now for many months.
We will not be making any further changes to the old products, but by the same token we won't be forcing anyone to change to the new product set either.
19-09-2007 10:21 AM
In terms of forcing, I don't suggest plusnet is going to make anyone move to a new service. All I can say is, I see restrictions starting from 13gb that aren't guaranteed to work properly. I am not happy with this at all so seek resolution. The only resolution you can give me is a different plan. Now convince me that I am not in a corner on this one.
19-09-2007 10:24 AM
We can only give you the information. We can't make the decision for you
19-09-2007 10:25 AM
O2 recently decided to remove the ability to use monthly included minutes to dial 0845 and 0870 numbers, bringing them in line with all the other networks.
They had to give notice of this change, which will take place at the end September and if it's to the users detriment they can cease the contract with only the 30 days notice to pay. (I found it to my detriment and gave notice.)
A similar e-mail would have been issued from PlusNet when changing the terms of the Premier product and it's up to the user to review how the changes would affect them.
19-09-2007 10:38 AM
But as has been said before by staff, an e-mail would have been delivered to you.
19-09-2007 10:45 AM
