Powerline adapters wont connect after joining Plusnet
FIXED- Subscribe to RSS Feed
- Powerline adapters wont connect after joining Plus...
27-02-2024 6:33 PM
I've just joined plusnet and set up my router today. My Wi-Fi works fine.
My powerline adapters however, have stopped working, I can confirm they were previously working with my old ISP and the plugs have not been changed. I have reset the adapters and reset router to default settings. The adapter must be working slighty as I am able to reach the Admin portal as well as my media server which is also connected to the powerline adapter. My PC just shows 'unidentified network' and I have no connection. Am I missing some router setting to enable?
The adapters are TP-Link AV600
Fixed! Go to the fix.
27-02-2024 6:45 PM
I've managed to fix this, my PC had a static IP assigned which i have reset to Automatic.
(Win11) Network & Internet -> Ethernet -> IP Assignment.
I've checked on the hub manager and I seem to have the same IP assigned anyway, we'll see if I lose access again later in the future ![]()
