Powering the BT Modem & Plusnet Router off for sveral weeks
- Powering the BT Modem & Plusnet Router off for sve...
15-04-2013 11:58 AM
Any reason not to do this if i am away for a few weeks? I prefer to have all power blocks turned off whilst on holls.
Does the exchange mind having a break, i always did this with my O2 ADSL+ without any problems, but not sure if the fibre circuit is more touchy or not.
Message 1 of 4
(715 Views)
3 REPLIES 3
Re: Powering the BT Modem & Plusnet Router off for sveral weeks
15-04-2013 12:08 PM
Quote Any reason not to do this if i am away for a few weeks?
None whatsoever. It's only a problem if it's switched on & off regularly e.g every day , then the exchange thinks the line is unstable.
Message 2 of 4
(405 Views)
15-04-2013 2:57 PM
Still probably better to drop the connection via the 'disconnect' button on the router's interface before you do turn it off though. As MisterW says it should be fine without as it'll be off for some time, but it's still good practice
Message 3 of 4
(405 Views)
15-04-2013 3:55 PM
Thanks for the replies, all makes good sense
Message 4 of 4
(405 Views)
