Power supply specs for AR11 adsl router
- Power supply specs for AR11 adsl router
26-02-2008 8:41 PM
I have an old aceex AR11 adsl modem/router as supplied by Freeonline back in 2002. I haven't used it for a while as its power supply failed and as I had a speedtouch spare I simply replaced the modem and threw away the duff power supply.
Now I want to try the old modem again but I can't find any information on its power requirements.
Anyone out there who's still got an AR11 and can tell me what their power supply is rated at?
Message 1 of 7
(1,394 Views)
6 REPLIES 6
Re: Power supply specs for AR11 adsl router
26-02-2008 9:02 PM
a quick Google search came up with 9V AC 1.5 amp
Message 2 of 7
(680 Views)
26-02-2008 11:12 PM
Thanks, I spent ages googling. Where did you find that?
AC is unusual. I'll take the unit to pieces & see if there are any clues there.
Message 3 of 7
(680 Views)
26-02-2008 11:24 PM
Most equipment that uses a power brick should state on a label or by the power connector what the power requirements are for it.
Message 4 of 7
(680 Views)
26-02-2008 11:27 PM
You would think that but no, it just says 'Power'.
And there are no clues on the PCB either.
Message 5 of 7
(680 Views)
27-02-2008 7:25 AM
Quote from: pch Thanks, I spent ages googling. Where did you find that?
I got a copy of the manual from linky device manuals
Message 6 of 7
(680 Views)
27-02-2008 8:36 AM
Ah yes, I've been there. That's the manual for the A2R11, but no matter, at least it's in pdf form. The manual for the AR11 is a self-extracting zip file that is corrupted so it can't be opened.
I've found a 9V AC power supply on eBay, it just happens to come with a BT Voyager 190 ADSL modem so that should sort me out for less than a fiver anyway.
Thanks to both of you for your help, and one day I might get my adsl speed back again (currently 730kbs, used to be reliably over 2200kbs).
Message 7 of 7
(680 Views)
