Potential new customer
Strat
Fixes: 565
A good friend is wishing to leave Virgin Media after a number of lengthy disconnections.
He's been posting on Facebook about his issues and I recommended Plusnet....yeah...I know Undecided
He phoned PN and was told there would be a £50 charge for a BT line which he tells me he has.
I suggested he call 17070 to retrieve the number on the line....
many thanks. Getting a dialing sound on bt line will try that
i have rung the number got my BT number for the dead line, rung Plusnet and their computer still says no line to this property but i have just used it to call plusnet
The discussion is ongoing.
14 REPLIES 14
Fixes: 160
Re: Potential new customer
If BTOR's computer systems says no ...  Huh
Strat
Fixes: 565
He's passed me the number and it checks out as a non-BT line Sad which prsumably means a £49.99 charge for moving it.
Anotherone
Champion
Fixes: 21
If the line responds to 17070 it's a BTw line whatever else the systems say. Sounds like it's a Stopped line for which there should be no charge! How did you deduce it's a non-BT line Dick?
Strat
Fixes: 565
When I put his number into this...
Welcome to the Broadband Availability checker. This will provide a provisional check of your ability to receive reliable Broadband services.
Please enter your telephone number.
There is no data available for this number. This could be either because it is not a BT line or it is a new BT number that has just been provided. Most new numbers will appear on the checker 24 hours after BT has installed the line.
Anotherone
Champion
Fixes: 21
I think that will appear on a stopped line, which usually has dial-tone anyway. As for making 0800 calls on a stopped line, interesting, never tried that or thought of it, but I bet no other calls can be made on it?
Fixes: 160
Quote from: Anotherone
I believe that Talktalk LLU lines respond to 17070 but not as we know it.  You do not get line test facilities, but it does identify the line number.
Anotherone
Champion
Fixes: 21
I haven't been on a TalkTalk line for years, so can't confirm either way then.
Estragon
Sky LLU lines do. The 17070 test is slightly different for them.
I don't think TT do 17070.
Anotherone
Champion
Fixes: 21
I've checked on TalkTalk, it only gives the number and no options. I'm going to check Sky just for the record.
jelv
Fixes: 10
On the BTw checker LLU lines give
Quote from: Strat
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Anotherone
Champion
Fixes: 21
As Dick said in reply #4.
Just to be clearer, on a BTw line the announcement is " This circuit is identified as <telephone number>" It then says "BT Line Test facilities" and then gives options.
Anotherone
Champion
Fixes: 21
I'm told that on a Sky line it should give the following options -
1) Caller Display Information
2) How well I can hear you talking
3) Digital Tones
4) Echo or Noise problems
So that should help narrow it down Dick.
If it's actually a working LLU line (you can make calls other than 0800), there should be no charge - see the Plusnet Talk price guide
pvmb
When I was with TalkTalk a year or two back, they did have 17070. But it only gave the line number, no tests.
Also, I believe there was a code you could enter to switch over to the BT 17070 test and then switch back again, as I saw a BTOR engineer apparently doing just this to carry out the  BT Line Test at my home and then revert to TalkTalk.
Anotherone
Champion
Fixes: 21
That comes as no surprise, there are quite a few engineering codes to do all sorts of things, a lot of which will/may have changed since I last had a tinker.
