Postini Log In How
Gel
Seasoned Pro
Fixes: 13
Postini Log In How
I've tried but failed to log in on postini.
ie
XXX(username).plus.com
password
Yet I can't log in.
Any advice please. Roll eyes
Fixes: 10
Re: Postini Log In How
postini.default@username.plus.com
or
postini.default@mydomain.co.uk
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Gel
Seasoned Pro
Fixes: 13
Gel
Seasoned Pro
Fixes: 13
I hadn't enable quarantining apparently so + Net turned on for me;
however I still can't log in to Postini Undecided
LiamM
Don't know if its the same for the PlusNet postini quarantine, but I can't login to the Message Center for my business domain currently either (we use Postini filtering).  It tells me the service is under maintenance :-
We are performing scheduled maintenance on our systems.
The Message Center, Search Console, and Administration Console are temporarily unavailable.
Your email service is not affected, and your incoming and outgoing messages are being protected and delivered as usual.
We apologize for the inconvenience. Please try to log in at a later time.
Fixes: 10
I've just tried and got in no bother.
Postini have a number of centres around the world - it's highly unlikely that you are on the same one Liam - unless it's a US ISP account your using!
