Post scans
Fixes: 5
Post scans
I don't mind the random port scan, but I start to become a tad suspicious of port scans over a period of 3 days from the  same plusnet IP.
<84> May 16 16:12:06 IDS scan parser : tcp port scan: 84.93.230.186 scanned at least 10 ports at 146.200.196.131.  (1 of 1) : 84.93.230.186  146.200.196.131 0040 TCP 80->14710 [.FA...] seq 299907060 ack 4209427391 win 111
<84> May 16 22:34:58 IDS scan parser : tcp port scan: 84.93.230.186 scanned at least 10 ports at 146.200.196.xxx.  (1 of 1) : 84.93.230.186  146.200.196.xxx 0040 TCP 80->13780 [.FA...] seq 2707981615 ack 3940141635 win 111
<84> May 17 19:41:44 IDS scan parser : tcp port scan: 84.93.230.186 scanned at least 10 ports at 146.200.196.xxx.  (1 of 1) : 84.93.230.186  146.200.196.xxx 0040 TCP 80->14375 [.FA...] seq 2328577751 ack 1519961124 win 207
<84> May 18 09:37:03 IDS scan parser : tcp port scan: 84.93.230.186 scanned at least 10 ports at 146.200.196.xxx.  (1 of 1) : 84.93.230.186  146.200.196.xxx 0040 TCP 80->15534 [.FA...] seq 3595708792 ack 847252859 win 112
<84> May 18 22:14:57 IDS scan parser : tcp port scan: 84.93.230.186 scanned at least 10 ports at 146.200.196.xxx.  (1 of 1) : 84.93.230.186  146.200.196.xxx 0040 TCP 80->16153 [.FA...] seq 253658502 ack 4101414955 win 112
Does anyone have any info on this server "community03.servers.plus.net" ?  Undecided
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Post scans
It's one of the servers that we use for the Community Site - I can't see it being anything to worry about.
Chris Pettitt
Cloud Environments Engineer
Fixes: 5
Re: Post scans
Thanks Chris,
I'm not worried, just puzzled.
Why has a plusnet "community server" taken such an interest in my ports.  Cheesy
Fixes: 16
Re: Post scans
This has been reported previously
https://community.plus.net/forum/index.php/topic,117757.0.html
https://community.plus.net/forum/index.php/topic,126255.msg1097866.html#msg1097866
I don't know why you've only recently started noticing it. The suprious packets arrive during or shortly after you browse these forums. The source port would be 44340 if you use https, otherwise the source port is 80.
