Possibly on wrong cabinet (FTTC)
- Possibly on wrong cabinet (FTTC)
03-06-2013 2:20 AM
Re: Possibly on wrong cabinet (FTTC)
03-06-2013 3:12 AM
03-06-2013 3:34 AM
03-06-2013 6:07 AM
03-06-2013 6:11 AM
03-06-2013 6:54 AM
Is the cable coming into your house overhead or underground?
03-06-2013 7:09 AM
Both cabinets are on the same exchange and all cables on this exchange are all in underground ducts.
Quote from: itsme Are both cabinets on the same exchange?
03-06-2013 8:24 AM
.I'm no expert but I don't think there is any way to "force" Openreach to pull a new cable thru from a different cab, even for megabucks!!.
03-06-2013 9:29 AM
03-06-2013 4:43 PM
03-06-2013 5:53 PM
It the houses are fed by telegraph poles then it's probably unlikely they would switch you.
03-06-2013 6:55 PM
all the cables are underground including the cable to my property.
Quote from: itsme The question I ask was whether the cable into the house is underground. If it is and there are no telegraph poles used to connect the houses to the street cabinets than it's very unlikely that you could be switched to a different cabinet.
03-06-2013 7:34 PM
Changing the Mapping of 1 D'side pair would involve a lot of work,as they would have to possibly dig up footpaths,and roads even ,put ducting in and run a new cable for just you
Also there are a lot of D'side cables that aren't in ducting but are buried just below the paving flags in the soil and if BT openreach agreed to do this work it would cost you more than what they are quoting for FOD Fibre on Demand , So it wouldn't be really viable to you , Better waiting and getting FOD if you want a really fast connection go Full fibre
03-06-2013 7:41 PM
From what an openreach engineer told me a few weeks back FOD won't be available in my area .
Quote from: deathtrap My take on this would be no, as it's not something that BT Openreach would normally do , The FTTC cab that you are connected to is dependant on the PCP that it connects to, Changing the Mapping of 1 D'side pair would involve a lot of work, as there are a lot of D'side cables that aren't in ducting but are buried just below the paving flags and if BT openreach agreed to do this work it would cost you more than what they are quoting for FOD Fibre on Demand , So it wouldn't be really viable to you , Better waiting and getting FOD if you want a really fast connection go Full fibre
03-06-2013 7:44 PM
