Possible upgrade to FTTC ?
hevans
I have seen a few posting here about fibre and wonder if this is available as an upgrade. I am on the Aberystwyth exchange (WNAE I think) and I have a green cabinet about 15 metres from my front door. The dsl checker doesn't list it but I note that on your website it says that it is available at my phone number.
If this is possible I am assuming that the whole connection from your server to my router would be pretty much a high spec apart from the last 15 metres of copper from the cabinet to my phone socket.
I currently live/work abroad for a total of a few months every year and am probably going to be working from my house a lot more next year when I finish at my current office so need to know that I have a pretty much bullet proof connection when in the UK now that I will not have the 'spare' connection to use.
Fixes: 247
Re: Possible upgrade to FTTC ?
if you put your phone number in here it should tell you what you can get https://www.btwholesale.com/pages/static/Community/Broadband_Community/Coverage/ADSL_Availibility_Ch...
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
hevans
Cheers dvorak.
It looks like it is not an option yet.
Huw.
