Possible stuck PN profile (20CN)
- Possible stuck PN profile (20CN)
27-03-2012 4:04 AM
Hi, I had a pipe burst just under 2 weeks ago which caused the phone to stop working and the internet connection to become very slow and unstable. The test socket worked for the phone at the time so presumably water had got into the internal wiring somewhere but I was unable to test the modem on there. The phone is now working again and the modem's line stats have returned almost to normal but the connection is still very slow.
Over the last 24 hours or so I've run BT's speedtest a number of times with the line profile ranging from 4.5 Mbps to 6 Mbps. During the same time I have also moved the modem from it's usual extension socket to the test socket with no noticeable difference other than the attenuation dropping by 1 in each direction.
I've waited for Plusnet's line profile to update but it is still stuck at 0.25 Mbps. Does it need to be manually updated? Or is there something else I'm missing?
The current line stats (down/up) on the test socket are:
SNR Margin - 15/29
Attenuation - 3/0
Data Rate - 6816/448
SNR Margin - 15/29
Attenuation - 3/0
Message 1 of 4
(988 Views)
3 REPLIES 3
Re: Possible stuck PN profile (20CN)
27-03-2012 8:07 AM
Morning!
We have your line profiled at 5500Kbps, the same as on the BT system.
Could you reboot your router and see if you are still experiencing the poor speeds?
Message 2 of 4
(467 Views)
27-03-2012 8:08 AM
The profile update only happened a couple of minutes ago at this side.
Message 3 of 4
(467 Views)
27-03-2012 2:22 PM
Ah, typical that it would sort itself out a few hours after I posted. Yep, it's working great now, thank you.
Message 4 of 4
(467 Views)
