Possible speed
- Possible speed
Possible speed
27-03-2015 5:37 PM
I have recently joined plusnet from sky and have been reading through the forums quite a lot.
I am receiving roughly the same speed with plusnet as I was previously with sky but I'm just wondering if that is the max I can get out of my line.
I have looked on the kitz site and completed a bt wholesale speed test with the attached results.
The one that got me thinking was the BT test which says 21 Mbps for the max achievable speed. Does this mean my line could reach this speed or is that just that ADSL can go up to that speed?
Would be nice to try and get a bit extra out of it if I could.
Thanks in advance.
Re: Possible speed
27-03-2015 5:47 PM
Re: Possible speed
27-03-2015 5:49 PM
Thanks for the reply, I have only been with plusnet for a few days, so am I better waiting a little while to see if things settle down (and stop being so impatient :D) or should I carry on with some tests?
Re: Possible speed
27-03-2015 5:53 PM
Re: Possible speed
27-03-2015 5:54 PM
Out of interest with my stats what sort of sync speed would you expect to see?
Re: Possible speed
27-03-2015 6:06 PM
Re: Possible speed
27-03-2015 6:18 PM
The upper value of the acceptable range of speeds from the BT speedtester is largely meaningless, the range given is entirely based on your current line speed, it doesn't imply any maximum capability of your line. The ranges can be found on page 10 of the Slow Throughput Best Practice Guide (although much of that document is outdated).
Re: Possible speed
27-03-2015 6:53 PM
Re: Possible speed
27-03-2015 8:26 PM
Just to clarify do you believe that I should be getting speeds nearer 18Mb?
Also this may be a daft question but would my IP profile have an effect on this as the BT test is showing my IP Profile as just over 11 yet the kitz estimate is showing a much higher profile?
I may be on the completely wrong track here.
Re: Possible speed
27-03-2015 8:42 PM
Re: Possible speed
27-03-2015 9:12 PM
Re: Possible speed
28-03-2015 8:47 AM
I have now plugged my router into the BT master socket, but if anything my speed has become slightly slower.
Attached is the bt speed test and my router stats at the moment.
Re: Possible speed
28-03-2015 9:04 AM
Using the test socket should eliminate any possible adverse effects from extension wiring unless it's a bodge job (if you have no extension wiring it probably won't make any difference, although it's just possible the faceplate socket could be faulty or dirty, so still worth doing.)
Don't experiment too much though - frequent manual disconnections can cause problems in their own right if the DLM thinks there's a fault on your line.
Re: Possible speed
28-03-2015 9:52 AM
I've just plugged it straight into the test socket and now getting the attached results on my router. Which looks like a big improvement.
I take it for the speed to actually increase it would take a little while for things to update?
Re: Possible speed
28-03-2015 10:09 AM
Leave it in the test socket if you can (I'm assuming you must have extension wiring for that improvement to occur, so you'll probably find any phone extensions don't work now.)
