Possible routing issue
Fixes: 5
Can anyone access http://getpocket.com
I can not access or ping it directly but ok if I go through a proxy.
Gateway: ag06
Re: Possible routing issue
Working fine here.
Which gateway
You are currently connected to gateway ptw-ag02.
This is located in Telehouse West.
Fixes: 5
Quote from: Jaggies
Why do you think that?
Also tried these gateways without any success.
ag08 no access
ag03 no access
ag06 no access
ag01 no access
Fixes: 16
I can access it fine and I'm on pcl-ag06.
getpocket.com seems to be 23.21.237.192 and 50.17.230.90, regardless of which DNS server you're using, traceroutes to either of those addresses disappear into Amazon's network.
Apprentice
Ping times out, however the website loads OK
C:\Documents and Settings\Alastair>tracert pocket.com
Tracing route to pocket.com [64.132.6.38]
over a maximum of 30 hops:
  1    *        *        *    Request timed out.
  2    57 ms    51 ms    56 ms  lo0-central10.pcl-ag01.plus.net [195.166.128.182]
  3    51 ms    51 ms    51 ms  link-b-central10.pcl-gw02.plus.net [212.159.2.162]
  4    50 ms    50 ms    51 ms  xe-10-0-0.pcl-cr02.plus.net [212.159.0.194]
  5    52 ms    53 ms    52 ms  ae1.ptw-cr02.plus.net [195.166.129.2]
  6    53 ms    51 ms    51 ms  ae2.ptw-cr01.plus.net [195.166.129.4]
  7    52 ms    *      224 ms  te-3-4.car5.London1.Level3.net [217.163.45.181]
  8  131 ms  132 ms  131 ms  ae-52-52.csw2.London1.Level3.net [4.69.139.120]
  9  132 ms  132 ms  132 ms  ae-59-224.ebr2.London1.Level3.net [4.69.153.141]
10  132 ms  132 ms  133 ms  ae-42-42.ebr1.NewYork1.Level3.net [4.69.137.70]
11  132 ms  133 ms  133 ms  4.69.201.62
12  132 ms  134 ms  132 ms  4.69.202.61
13  133 ms  133 ms  132 ms  ae-92-92.csw4.Washington1.Level3.net [4.69.134.158]
14  137 ms  131 ms  133 ms  ae-4-90.edge2.Washington4.Level3.net [4.69.149.208]
15  132 ms  133 ms  132 ms  TWTC-level3-1x10G.Washington.Level3.net [4.53.114.10]
16  172 ms  171 ms  171 ms  sat1-ar3-xe-2-0-0-0.us.twtelecom.net [66.192.244.170]
17  179 ms  181 ms  180 ms  64.132.228.74
18    *        *        *    Request timed out.
19    *        *        *    Request timed out.
20    *        *        *    Request timed out.
21    *        *        *    Request timed out.
22  ^C
Fixes: 16
Quote from: Apprentice
You've gone to pocket.com instead of getpocket.com
Fixes: 4
I can browse to it on pcl-ag07
Fixes: 5
Thanks all.
Just changed from firefox to IE and the site now loads.  Undecided
I'll post back when I find what the problem is with firefox.
Edit:
Cleared Firefox cache and now loading.  Embarrassed
Apprentice
Quote from: ejs
Ouch,looks like it's maybe time for me to visit them in the not too distant  Sad
