Possible routing issue
- Re: Possible routing issue
17-10-2013 9:18 PM
Can anyone access http://getpocket.com
I can not access or ping it directly but ok if I go through a proxy.
Gateway: ag06
Gateway: ag06
Message 1 of 9
(1,511 Views)
8 REPLIES 8
17-10-2013 9:25 PM
Working fine here.
Which gateway
You are currently connected to gateway ptw-ag02.
This is located in Telehouse West.
Which gateway
Message 2 of 9
(621 Views)
17-10-2013 9:40 PM
Quote from: Jaggies
Why do you think that?
Also tried these gateways without any success.
ag08 no access
ag03 no access
ag06 no access
ag01 no access
Message 3 of 9
(621 Views)
17-10-2013 9:41 PM
I can access it fine and I'm on pcl-ag06.
getpocket.com seems to be 23.21.237.192 and 50.17.230.90, regardless of which DNS server you're using, traceroutes to either of those addresses disappear into Amazon's network.
Message 4 of 9
(621 Views)
17-10-2013 9:42 PM
Ping times out, however the website loads OK
C:\Documents and Settings\Alastair>tracert pocket.com
Tracing route to pocket.com [64.132.6.38]
over a maximum of 30 hops:
1 * * * Request timed out.
2 57 ms 51 ms 56 ms lo0-central10.pcl-ag01.plus.net [195.166.128.182]
3 51 ms 51 ms 51 ms link-b-central10.pcl-gw02.plus.net [212.159.2.162]
4 50 ms 50 ms 51 ms xe-10-0-0.pcl-cr02.plus.net [212.159.0.194]
5 52 ms 53 ms 52 ms ae1.ptw-cr02.plus.net [195.166.129.2]
6 53 ms 51 ms 51 ms ae2.ptw-cr01.plus.net [195.166.129.4]
7 52 ms * 224 ms te-3-4.car5.London1.Level3.net [217.163.45.181]
8 131 ms 132 ms 131 ms ae-52-52.csw2.London1.Level3.net [4.69.139.120]
9 132 ms 132 ms 132 ms ae-59-224.ebr2.London1.Level3.net [4.69.153.141]
10 132 ms 132 ms 133 ms ae-42-42.ebr1.NewYork1.Level3.net [4.69.137.70]
11 132 ms 133 ms 133 ms 4.69.201.62
12 132 ms 134 ms 132 ms 4.69.202.61
13 133 ms 133 ms 132 ms ae-92-92.csw4.Washington1.Level3.net [4.69.134.158]
14 137 ms 131 ms 133 ms ae-4-90.edge2.Washington4.Level3.net [4.69.149.208]
15 132 ms 133 ms 132 ms TWTC-level3-1x10G.Washington.Level3.net [4.53.114.10]
16 172 ms 171 ms 171 ms sat1-ar3-xe-2-0-0-0.us.twtelecom.net [66.192.244.170]
17 179 ms 181 ms 180 ms 64.132.228.74
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 ^C
22 ^C
Message 5 of 9
(621 Views)
17-10-2013 9:47 PM
Quote from: Apprentice C:\Documents and Settings\Alastair>tracert pocket.com
You've gone to pocket.com instead of getpocket.com
Message 6 of 9
(621 Views)
17-10-2013 9:50 PM
I can browse to it on pcl-ag07
Message 7 of 9
(621 Views)
17-10-2013 9:56 PM
Thanks all.
Just changed from firefox to IE and the site now loads.
I'll post back when I find what the problem is with firefox.
Edit:
Cleared Firefox cache and now loading.
Edit:
Message 8 of 9
(621 Views)
18-10-2013 6:17 PM
Quote from: ejs
Ouch,looks like it's maybe time for me to visit them in the not too distant
Message 9 of 9
(621 Views)
